Tesla is the father of the TPU
Started by bajac, April 25, 2010, 12:42:34 PM
Do you really know Tesla work and what it represents for our future?
Letter
7 (87.5%)
1 (12.5%)
Total Members Voted: 8
innovation_station
Quote from: giantkiller on April 27, 2010, 02:45:49 PM
You only need 1 FLB and 1 spark gap to produce huge amounts of energy. Any more than that and it is useless. Resonance is the action of 1 source against 1 target timed correctly. Period. The materials are simply your choice.
Since it is Tesla, why the show and tell of massive mechanical and abundance? Are you trying to show and teach?
Mr. Hilsfinger, you have done a great job exposing yourself to the powers that be. Should you at any time power on your devices and power your house in a demo for all the world to see: that will the last switch you turn...
Prove me wrong on this one, my friend. You are already in the cross hairs. Play the fool and stay alive. Be the fool and be over.
IS THAT SO ...  ?
clearly you missed how this works aswell ..
what is my input ?   what is the job of my device ... does it USE A SPARK GAP ?  it does use a spark gap .. but a timed one .. there is a spark present upon colapse at the switched contact  but this is not on the input of the unit ... this is an effect of the unit ... upon colpase
IST!
answer no it does not use a spark gap ...  it runs on verry low inputted engery .. eb solar salt water  cosmic
you know gk this operates  on princibales i heve publiclly released years ago ...  my first invention ...
regards !   what is the diff mechanical non mechanical ?   besides how do you know what i will do with MY DEVICE?  HUMMMM ?   yea ...
you have no idea how my unit works .. and i will tell ya why ... you never built it i did . and am doing so ... there for you can not pick my work apart as it is mine not yours ... and you dont know the rest of the unit so ...
go fish!
this can and will power a HUGE MOTOR ...  im designing  so i do find it all so intresting those telling me how my inventions work .. or will work when they have no idea the origonal design for it ...
all my units serve multi uses !
not to be rude but im an inventor and i build things ...  so  yea .. this is a LOW VOLTAGE DEVICE ..
it has 4 inputs solar earth battery salt water cell aux!  so what ever i cant change who i am nor would i
giantkiller
The mechanical rotary switch is the spark gap.
You have successfully reproduced parts of the Tesla Ionizer with parts of Don Smiths circuit. A hybrid, if you will.
The rotary switch causes a high speed connection which causes a shock wave prior to conduction. The capacitors absorb this high rate of energy. The load then draws this off slowly. Your circuit merely stores up the inrush faster than the load can use it.
It can be done a thousands ways. What you have done is nothing new but I know you are proud of your work. It shows in your craftsmanship. Show the same concern to your fellow humans. Reality is like a mirror. It only reflects our image. How are you talking to the world? And what do you want back? Use it like the golden rule and you will remain safe from the harm caused by others.
In example: Don't piss off the apes if you're in the cage with them. Sounds like you are in both cases.
So drop the petty contrivances with the others and get you work done. Remain humble and be not proud. Avoid the noise and clammer lest you become one with it and perform no good at all.
innovation_station
Quote from: giantkiller on April 27, 2010, 03:46:54 PM
what are the requirements to be considered a spark gap ?
im not sure i will have a rotary spark gap on the input at low voltage  low amparage ... there will be a fly back spark of HEMF HIGH ELECTRO MOTIVE FORCE ..
... on out put it could be or i can cap it now it is self powering .. from the first KICK..
AGIN MY WORK ...  same as my turbine self running design ... with a gear pump or tesla pump on the out put of the turbine ... wind it up and let it go ...
ist!
who the hell cares how the pressure is put into the system the first time ... as long as it is there ..  eh!
i could crank the turbine over till pressure is built then release upon its self .. as per turbine design ..
innovation_station
It can be done a thousands ways. What you have done is nothing new but I know you are proud of your work. It shows in your craftsmanship. Show the same concern to your fellow humans. Reality is like a mirror. It only reflects our image. How are you talking to the world? And what do you want back. Use it like the golden rule and you will remain safe from the harm caused by others.
im simply shareing what i have come to re know ...  indeed ...
so i have choosen to share it opensource as i always have ..
i encourage people to innovate there own ways to the roots ... but never loose the roots .. your plant will die ..
ist!
giantkiller
So what? You going to let some flies ruin your picnic? What is the larger goal you want to achieve?
Tell your dad the same thing I told you here. He will agree and tell you the same. Now move on, keep your chin up and your nose down. Finish your goal to win.
Intelligence shown is the value of wisdom given. Share with peace.
The goal is get finished not get even.
Quote from: innovation_station on April 27, 2010, 04:08:11 PM
im simply shareing what i have come to re know ... and im pissed at gay frogs that steal my work and try to take my hat  ... the little fuckers are gonna burn !
so
