Tesla is the father of the TPU
Started by bajac, April 25, 2010, 12:42:34 PM
Do you really know Tesla work and what it represents for our future?
Letter
7 (87.5%)
1 (12.5%)
Total Members Voted: 8
innovation_station
it is time to ask the question ...  what is the gyro motion of a tpu .. ?
i have an answer .. and it does not have to spin to get this effect !
ist
giantkiller
You can fill caps with kicks. But the rotation is equivilant to motion. Kick the rotation as it comes around. In synch.
Lidmotor showed a regular coil spinning a neo magnetic inside the spool. It takes alot of current. But what if you hit it at the right time at lower current? This would make the horizontal windings the driver and the vertical windings the collector. I switched the aforementioned coil operation. Because if we are pumping the horizontal magnetic field around the ring and modulating the amplitude that activity would cut across the many wires of the vertical windings, what we call the control. And this would fit in with what Don Smith said about the 'Charge pumping' the power supply. This would also fit the model of DC with hash on it. This would also fit with the cannon ball posts. With a copper core we have an interface between the flux and the copper's internal electrons with no eddy current problems. Less resistance.
In reading about Townsend Brown and Evgeny Podkletnov they both said that when you hit what is in front of the anode with a hard pulse i.e. high voltage and 1 high frequency the interference is fierce and one is able move it. Said another way is you can push it. The frequency they used was 100khz to 1 mega hertz. That is a 555 to a fet. The Fet has a fast enough 'on' transistion time. Like smacking water too hard. It doesnt give way immediately but transmits the pressure (kinetic and audio) quite easily.
The TPU is sub energy wave behavior. The results look somewhat like Deyo's smoke demo showed but we use a toriodal magnetic field to present the medium of control or pathway.
Even though the fluctuations of the field extending radially are parallel with the vertical wires the pulsing actually flies perpendicular to those vertical windings.
The mobius wiring configuration of the GK4 that Otto posted actually interleaves the operation by alternating the vertically and the horizontal operation. That is why it spewed radially.
innovation_station
sure ..
there much simpler ways that work HAND IN HAND so to speak ..
ist
verry much how push and pull operates ..
1 switch
it ramps and amps non freq dependent !
if done properly you can have the MAGNET SWITCH KICK STARTER  to start the operation of it so in essance you swipe the magnet make a kick .. it goes to a cap .. this cap powers phase 1
ok  hope i havent lost anyone ..
now  the magnet is THEN PROPERLY OREINTATED TO THE PROPER COIL.. and set there.. to serve as the hall effect amp ..  : )
and i will let your  mind wonder
i have much better designs aswell
useing a super cap as the source .. you DO NOT NEED THE MAGNET SWITCH KICK STARTER ..  simply pre charge the cap .. then modulate output 1 2 1 2  1 is source feed back  2 is phase 2 supply
innovation_station
Quote from: giantkiller on May 04, 2010, 01:10:27 PM
dude when modulating .. simply modulate the out put ..
need a video ? : )
i got 1
2 freq modulation  by hand lol
watch this
http://www.youtube.com/watch?v=r5FmO55sBAU
so .. after viewing my video ..  you send the NORMAL jt SPIKES back to source to replinish .. the LARGE spikes you see are sent to phase 2
b4 you even ask there NO CAPS IN THAT SYSTEM...
i have seen flying feilds blow things .. it was not visual .. how ever   it was a 1/4 meggawatt diode ..  at a distance of 4 feet from my coil ...  hummmmmm
it pissed me off!  and i never picked up the damm thing agin ..
innovation_station
now i have a phase 2 system that runs with gain BIG TIME !
as well i have the video proof to back it up
regards !
it consumes micro amps .. at low volts returning much higher volts ..  in some cases 10 volts VHF  and i mean VHF..
now when taken to full 12vdc supply it consumes 3.1 miliamps  while returning 70 volts  AGIN VERRY HIGH FREQ ..
so  when i charge a 12vdc audio amp super cap of .5 f it runs this unit for close to  1 hour ..  the entire time putting out min 10 volts  if i turn the consumputin up to 40 ma at 12vdc im returned 600v spikes
agin   the same freq ..
ist
here is a video i speak of this coil ..
http://www.youtube.com/watch?v=_OvNtS8kEjk
