Can energy double?
Started by Zhang Yalin, April 25, 2010, 11:57:48 PM
Yes or No?
Yes.
3 (30%)
No.
7 (70%)
Total Members Voted: 10
cletushowell
Yes you can even double the speed of light but the car moves sideways by itself if you change it to water
The cheif prince of meshech
the_big_m_in_ok
Quote from: FreeEnergy on April 27, 2010, 03:38:09 AM
so how would you close the loop here? how will this self reset to repeat its process? you're saying the generator will provide enough energy to reset the system?
Do water mills that use a gravity wheel to spin a crankshaft work the same way?  Is your thought experiment equivalent to a mill wheel?  Does the mill wheel operating on a stream or dam spillway exhibit OU?
REEDIT:
I'd vote for undecided or "Don't Know" on the poll.  I've never thought of the concept, but the law of conservation of energy may be at work here.  I'm not sure, though.
--Lee
cletushowell
Ya simular to water wheel but leverage the water
by self leveling it the farther it goes the more leverage
the car does not self level
but beings were now off topic drunks kill
victims not due to the crash but due to energy
transfer there so wasted - ph when they hit a car they
are essentialy colliding the bomb
taking the positive energy from the sober people absorbing
it to the drunk the drunk lives sobers up the inocent die
so if you on opiates +ph and get hit by a drunk you neutralize
of course not counting other injuries this is why drunks live
in the wreck sad but true well figured id put that out before i forgot it
Low-Q
Quote from: Zhang Yalin on April 25, 2010, 11:57:48 PM
Can energy double?
If an iron ball weighting 10kg is placed on the edge of a table and let it drop pulling a toy car of the same weight from the top of the table, the frictional resistance of the car is 2kg. When the ball is about to reach the ground, the ball and the car both have the kinetic energy (10kg×10m-20)(20 by friction consumption), thus 100( potential energy) = 160(kinetic energy).
During the whole process, the ball travels vertically from the table top to the ground, while the car travels horizontally from one end of the table top to the other. If the car is attached to a generator set on the edge of the table, the colliding force will makes it work. And the same is true with the ball.
Some of the kinetic energy in the ball are consumed by the toy car so not all of the initial potential energy in the ball are converted to kinetic energy when it hits the ground. So the equation would be [100N -20N] x 10m = 800Joule, where the consumed energy of the toy car is 200Joule (20N x 10m). 800J + 200J = 1000J (The same as the weight of the ball falling freely for 10 meters). All the energy, no matter how you put it, are accounted for.
Vidar
the_big_m_in_ok
Can energy double?
With respect to this post and posted Reply #30,
Are you simply adding both the horizontal force of the car moving across the table and also the vertical force of the ball dropping?  If you can capture all the energy of both objects moving, I suppose you have a point.
But did anyone think of drag or inertia?  I think either or both would cancel the forward force acting on the objects.  "Conservation of Energy" as a concept comes to my mind, somehow.
--Lee
