My Perendev Replication
Started by matthew6060, April 27, 2010, 03:32:33 PM
Magluvin
Im not sure i would call it shielding. At the end of the pipe that is close to the open end is where the pole you are trying to shield will be. The iron just acts as a path to the other side, that is what magnet fields do is seek the other side. So at your opening, some of the field that you expect to be present will be attracted to the edge of the pipe for an easy path to the other side. So I cannot tell you for sure that it will help.
From what I know, Perendev used a different no. of mags on the shell as compared to the rotor so that only 1 rotor and shell mag are on top of one another and the rest are gradually out of sync.
Mags
Magluvin
Well  342 views so far, =]   Let it brew for a bit.
Mags
ramset
Well
Ehrfinder built a drum motor using a V gate config on the drum.
he had it on his web site [which I lost in a crash]
Does anybody have that address?
Putting a "gate" that works ,onto a drum ??
Chet
BTW
Mat
Nice build !
Welcome!
Thanks Grandma
matthew6060
well then today may be better spent exhausting all of the perendev information on this site before digging into this thing again.  ive also heard of using diametrically opposed magnets in the stator which effectively attract the rotor magnet toward them and then oppose them.  there are so many variables to this thing, i can see how people who work on stuff like this in their spare time can take a long time to get it all worked out.  i do know that in the original patent he called for shielding...
jacko
Nice work so far. You're going down the right road. I'm glad to see that you're using magnets alone, because that's all you need to make a device like this. Now I think you should forget about shielding, it wont make any difference in the long run! If you want to get this thing to spin, you have to get past the so called sticky spot. For to do that you have to try to get your outside ring to rotate againest the inner one. This could double your usable power output and cause the inner ring to run much faster, and with speed comes power.
