Inductive Kicker or Bug?
Started by DreamThinkBuild, April 27, 2010, 06:29:56 PM
e2matrix
Seems like it would be fairly easy to build this or something close to it.  Maybe just give it a real world try.  I was going to try testing it in LT Spice but it doesn't seem to have an import ability.  I may have another proggy that will do it - I guess the kick.txt file is what you would import?
innovation_station
you can always go optical switching but 5v is needed .. so you could use a jt and a led reciever on the fet but you may find a crystal diode is needed to get 5 v to fire the fet  but then you just turn the jt or MOVE THE MAGNET ON THE IST WJT TRANSFORMER
http://www.youtube.com/watch?v=xf2_mUt29LI
IST
Sprocket
@DreamThinkBuild - Hi.  Interesting circuit, never came across it till now.  I'm confused as to what your switches are!  I had a go simulating with Spice, trying both reed switches & mosfets.  Reeds were a no go, mosfets returned something reasonable when I modify the circuit a bit, (smaller inductor, bigger cap.) giving about 800V.  No run-away effect like you're seeing!  My effort isn't overly convincing though - selecting generic components rather than specific values like I've done returns something completely different!  Anyway, fun to play with.  I may even have a go at building it...
otto
Hello all,
nice work here.
Maybe you should change the 7404 with a 40XX IC so you can use a 9V battery or even a 12V car battery? Just a guess.
Otto
innovation_station
Quote from: otto on April 30, 2010, 12:45:04 AM
Hello all,
nice work here.
Otto
maybe you use a atmega or atmel  8515 : )  and program the damm thing ...  hummmmmmmm
ever hack free tv ?
ist!
8515 is a 40 pin dip ... lol  they make smaller ones for those that dont know it is a programable  microcontroller
some are made hardned !  hummmm still it is a waste of time as i can do it with out junk spark gap the flb
get rid of the diodes you will blow them ..  i lit 60 watt bubls from neo zapping alone and low self inductance . coils so do it right ... DROP THE 9VDC AND THE 12VDC ... AND MAKE IT RUN ON A WATCH BATTERY .....
HUMMMMMM
its all so simple ..  use the watch battery to make the large kick .. from the several henry coils .. use the returned kick to power the low inductance coil then neo zap it .. then load it ..
and it is then posibale  to start the coil with only the swipe of a magnet .. and a starter coil insted of the battery ..
where is the FROG NOW TO TELL THE WORLD THIS IS HIS WORK !!!!
I THOUGH SO ....
LITTLE FAG HE IS ...    TRY AND TAKE MY HAT !
nuttin on the top but a bucket and a mop .. and an ILISTRATED BOOK ABOUT BIRDS ...  see a lot up there but dont be scared WHO NEEDS ACTION WHEN I GOT MY WORDS !
http://www.youtube.com/watch?v=G7RbCyxU_Uc
HORUS!
