Thanks to ALL for your help!!
Noah's ARK FOUND IN TURKEY!
Started by Bruce_TPU, April 27, 2010, 09:03:36 PM
Bruce_TPU
http://www.thesun.co.uk/sol/homepage/news/2949640/Noahs-Ark-found-in-Turkey.html
Be sure to watch the video there also!  I always suspected it would be found in our generation.  And this is the real deal, no losing the sight or can't find it, etc. etc as has been the case with so many spottings.
Cheers,
Bruce  (We do indeed live in the End Times...And I know whose side I stand on!)  I know who wins... I have read the end of the book!
ketone
Bunch of boards above 11,000 ft.....gimme DNA samples of animals that were on board and you'll make a believer out of me... ;)
and they ruled out a Human Settlement why?
call me agnostic.
FatChance!!!
Quote:
"It's not 100 per cent that it is Noah's Ark, but we think it is 99.9 per cent that this is it."
It's that 0.1% that will keep them from being right in this matter....
FreeEnergy
hmmm i thought the noah's ark was found already by a snowy mountain somewhere?
Groundloop
