Basic Bedin circuit
Started by resonanceman, April 30, 2010, 05:48:32 PM
resonanceman
Quote from: innovation_station on April 30, 2010, 10:53:55 PM
play with it see what ya get ..
i just released my self running unit today ..
it is also a neo zap switcher/ ampliflyer too
lol
has 0 transistors ...  just push it ...
lmfao!
ist
look at this super basic toy ..  lol
http://www.youtube.com/watch?v=wf3MH1Bb3uU
notice the sound of my motor toward the end of the demo ......  listen hard to the sound ...
i just love that video lol
i show how to make your motor accelerate ...   while under load .. hummmmm
the load can be the motor its self ...  hummm  it climbs in rpm while makeing a sparkie sound ..  hummm  it is feeding back after the transistor ...  HUMMMM A GAIN ....
via burnt out 33 ohm .. wich i made glow red hot in the demo b4 that one : )
IST where  is this 0 transistor thing?
Your bedini does go very fast .........personally  I would not  trust any kind of tape for holding  a motor together......It might work great for  proof  of concept but it  will eventually come apart........at 30,000 RPM that is not a good thing.
After  watching  your video I am thinking that my design should  be able to  hit speeds like that..... if I  go for the 4 inch dia  rotor
With  a bigger  rotor  it would be harder to reach those speeds and more dangerous.
I saw  you had  another video  with that same motor  describing a self running motor.  I did not  see a video with  the completed  motor....... did you make it?
If  you did  any work on it  I would like to hear about it.
What you described was alot like my plans.
No response about why NEOs should not  be used for bedinis.
Does this mean that no one here knows ?
gary
guruji
Hi Resonanceman I have used neos for a long time now with no problem.
innovation_station
that video you watched GOES WITH A HOLE SERRIES  THE IST MINI POWERSTACK
YES I HAVE FULLY EXPLAINED MY DEVICES !
MY DEVICES ......
IT IS ASWELL MY DESIGN AS PER A LONG TIME AGO .. I POSTED A PICTURE OF THE DESIGN ... QUITE SOME TIME AGO ...
NONE THE LESS
my powerstack  has quite A FEW TECKS IN IT ...
btw it is best you do your own thing ...
the rest of my unit wont be public for some time ... : )
perhaps you should try things b4 you run your mouth ...
my tape works well
: P
william
I started to play with that motor yesterday ..  with coils i have LAYING AROUND ...
it is built with the switcher disc on the back of it now ...  it does not wobble ...  anyway .. as per yesterdays expairments ..  so far useing coils i had .. it will not run on 2vdc ...
hence a freqcon so i pulled in a big old tv  for parts ...
watcher
Dn't know where to post, so write it here. For 3 years long watching at OU site, I'm asking self and others: Did anyone never try to build the device for household needs? All I could see here are only some models of BS. But it's well known that Bedini use the generator, one produce 10kw for his lab.
mscoffman
Quote from: watcher on May 17, 2010, 03:22:53 PM
Well, the device itself has been built. It is called the "Bedini 10 coiler".
You can Google and You-tube with this string to find out how people
are coming along. I would much rather build a two stage battery pack based
on the biggest deep cycle acid/lead storage batteries one could find and
carefully buffer that output into a modern electric automobile LmNh battery of
26KWh. A line interactive 100KW instantaneous AC inverter and switch would
finish up the system. Only 1.5KW continuous power is require for the average
household current electrical needs. Because the battery pack has a high cost
currently, but is dropping rapidly, I doubt many folk have gone all the way yet.
The acid/lead storage battery needs to be only a couple KWh so it would
be economically replacable since that is where the power most likely is generated.
:S:MarkSCoffman
