Basic Bedin circuit
Started by resonanceman, April 30, 2010, 05:48:32 PM
innovation_station
resonanceman
Quote from: Groundloop on April 30, 2010, 07:16:23 PM
@resonanceman,
The neon bulb is there to protect the transistor
against over voltage. If you disconnect the charge
battery then there is a high risk of blowing the
transistor.
The small bulb is like a RPM regulator on the motor.
The resistance in the bulb will vary with the
transistor base current. When the rpm increase
then the base current will be higher and the bulb
will "burn" more energy and the end result is that
the base current goes down again, thus keeping
the RPM stable.
Your JT experience will help. If you motor will not run
then just reverse one of the coils. Don't use Neos
on the rotor, use ferrite magnets. All north out. Also
get the coil as close to the magnets as possible.
A good rotor is the front wheel of a bicycle. Remove
the rubber tire and glue or use strong tape to hold
the magnets onto the wheel.
Good luck with your motor.
G.
Groundloop
Thanks for the advice  .......I will follow it.............well for a while  at least.
Well actually probably until I get a rotor spinning.
I  am here to experment .........I have LOTS of ideas......some of  them are things I wanted to do with a JT but  didn't have the power.
Just curious do  you know  why NEOs should not  be used?
I am thinking that they are to powerful and make it hard to not over rev  the  rotor.
If that is the case I want to  use NEOs  as soon as possible.
I was planning on  making a  rotor with N and S up.......( EDIT secondary rotor this is not the primary bedini rotor  )   and putting  a few coils  around it.,....... this  should  make  a fairly normal alternator....... It should help  limit speed  similar to the way  you described the grain of wheat bulb  limiting it.
One thing I want to avoid  is cutting the input to limit speed.
I want to limit  speed by extracting power.
I have added an attachment ... i don't remember  where I found it but  it looks interesting.........except the reed switch part........reed switches  suck when it comes to reliability......
Page 2 has a scope shot of a signal......I want to make pulses like that with no reed switch.
I also wonder  why no one is using  both poles of the magnets........other  than the over rev problem.......
I read that black iron oxide is as close  as we can get to ferrite .......I have some on the way.......my epoxy resin got here 2 days  ago.
I think it will make a better core than nails........it may take some experimenting to get the right density.
I plan on making a C core and  trying to tap  both poles.......with luck  I should come close to doubling  the power out.
I also plan on trying to make  a  large toroid for JTs.......but  ......it is  iron powder.........so  I will be lucky to make one  as good as  I could buy.........but I can make them bigger........that may have some value.
gary
innovation_station
have fun ..
waste of time
ist !
resonanceman
Quote from: innovation_station on April 30, 2010, 08:28:51 PM
gary do you want to build a motor?
if you do i will work with you public i have a fully duplicatable design that is self running ..
and if you want to build it i will build it with you public ..
useing a basic bedini controller but my motor is NO BEDINI LOL
its wayyyyyyyy better ...
regards ..
just push the thing ... : )
find some old vcrs ...
you can build it for cents ..
ist
the axel in this design is stationary only the wheel spins has 4 vcr bearings in it .. verry high rpm  like 30 000 plus
with this design you can even build the rotor of wood ..
and groundloop
HAVE YOU EVER BUILT A MOTOR WITH NEOS ..?  IF THE ANSWER IS NO WHO ARE YOU TO SAY DONT USE THEM ?
btw gl a bicycle wheel is USELESS!   I RECCOMEND A SMALL WHEEL ...   speed !  you want high volt high freq from your aux coils then rectify it .. to a cap
i say go CORELESS IF YOU HAVE ENOUGH WIRE ...
PS forget the reed switch they just blow up .. or wear out in time ..   : )
never mind the low voltage welding incidents you will have and suddenly weld the reed contacts ....
if done right you can do it with an aa ... a welding incident  that is ....
and if you mount the rotor vertical .. gravity is on your side ....
hummmmmmm
IST
I have seen  a bedini made with a VCR head on U tube........it was very fast.
I  have a pretty good idea  of what I want to end up  with.
I am shooting  for a fairly small  multi rotor design
I am thinking  of  using a plastic  tube for an outer housing........PVC water pipe ........or acrylic tube  if you have the money and want to show  it off.
I am  thinking  if  the rotors are well made and on a keyed shaft....... I only need one  trigger rotor.......... I can add as many power rotors as I  need.........of course I will need  a alternator rotor or 2 ( to keep the speed in check ) ........ I am thinking  there will probably be a set ratio of power rotors to alternator  rotors........
The  fan motor mods showed me that  you can  use separate coils .
going  coreless is an interesting idea........ it seems with a Newman motor   the idea is to mostly  make big  coils..... what about  one  magnet on a rotor........and  one coil on each side of the rotor?
The magnet would have to have N on one rotor face and S on the other.......but I was planning on doing that anyway.......for many reasons.
If  the coils  were about 3/4 of the  size of the rotor .........but one side  of each placed near the  Axel  it might  just  work like a Newman...... the coils could be pretty thick
The  coils could also  be closer to the rotor than with a normal Newman.
I am thinking that a coil that goes around the shaft.......then just past the outer edge of he rotor  disk  would be ideal.... squeezing the coil  into a line ....... then  putting a line  of magnets from the center of the rotor disk out to  the edge.......
I  agree on the higher speed thing............but I don't have any VCRs laying around.........and I don't plan on  anything like 30000 RPM
In  general a small disk  turns  faster  without  flying  apart....... I was thinking 6 in dia max........4 in may be better.
It depends on what parts I find to make it.
gary
innovation_station
play with it see what ya get ..
i just released my self running unit today ..
it is also a neo zap switcher/ ampliflyer too
lol
has 0 transistors ...  just push it ...
lmfao!
ist
look at this super basic toy ..  lol
http://www.youtube.com/watch?v=wf3MH1Bb3uU
notice the sound of my motor toward the end of the demo ......  listen hard to the sound ...
i just love that video lol
i show how to make your motor accelerate ...   while under load .. hummmmm
the load can be the motor its self ...  hummm  it climbs in rpm while makeing a sparkie sound ..  hummm  it is feeding back after the transistor ...  HUMMMM A GAIN ....
via burnt out 33 ohm .. wich i made glow red hot in the demo b4 that one : )
