Gulf Oil Spill - new record
Started by 4Tesla, May 01, 2010, 08:49:16 PM
sparks
    Geoligists have long felt that the Gulf was created by a large meteor strike.  Florida at one time a hilly mountainous jungle region was instantly transformed into the barely above sea level pennisula it is now by the shockwave.  The oil in the Gulf could be the remnants of what was once a large  land mass driven into the mantle by the impact.  Diamonds are often mined from meteor impact sites as any carbon is transformed instantly into diamonds from the heat and pressure of a meteor impact.  Imagine an entire country driven miles into the Earth.  This is not an ancient river delta oil reserve built up over thousands of years.  That process allows time for diffusion of the methane gas into the sedimentary rock as the carbon is slowly transformed by microbial action.  This is an instantaneous burial of a jungle deep into the Earth's mantle.  This would leave a high probability of voids filled with the remnants of the surface jungle existing below the Gulf mantle depression.  I am sure that BP did it's homework and knows the extent of the void it put it's needle in.  Time to put some underwater weldors down there and start burning this krap before it destroy's the entire atlantic ecosystem.  The gulf stream will move this shit all the way to Scotland and beyond taking life as it goes.
The entire marine population obtains it's energy from sunlight converting floating vegetation.  Just the stuff oil will be floating along with on it's trip to the polar regions in the Gulf Stream heat driven ocean river.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
nappolean
here is someone i hear, if u put the moon in the gulf it will fit perfectly.
raburgeson
I heard something really scary. That they would like to try to fuse the ground with a nuclear explosion. Have you ever tried to weld a leak on a vessel that has pressure on it? I don't think I have to say more about this.
the_big_m_in_ok
Quote from: 4Tesla on May 01, 2010, 08:49:16 PM
The MSM has done a lousy job at reporting on the oil spill crisis.  The truth is we have already surpassed the Exxon Valdez spill of 11 million gallons!
Here are some links to track the spill:
http://blog.skytruth.org/
http://www.skytruth.org/
http://earthobservatory.nasa.gov/NaturalHazards/view.php?id=43862
http://www.cnn.com/2010/US/04/29/interactive.spill.tracker/index.html
4Tesla
http://www.poynter.org/column.asp?id=2&aid=184196
The estimators have increased the minimum amount from 798,000 gals./day to what you see now.  I prefer the estimate:
http://www.guardian.co.uk/environment/2010/jun/12/bp-oil-spill-gulf-mexico
~= 1,600,000 gals./day
--Lee
