Thanks to ALL for your help!!
Finally - A Quick Cheap Natural and Legal Cure for Cancer
Started by Cap-Z-ro, May 06, 2010, 06:27:10 AM
Sprocket
Quote from: Thaelin on May 14, 2010, 11:39:07 AM
   I am just going on the old adage, an ounce of prevention. 5 out of the 7 in my
family died from cancer. I don't feel like participating thank you. Besides, its dirt
cheap and it helps my acidity problem a lot. On top of all that, I don't get sick any
more like I used to do. Puts your immune system in to hyper-drive.
thay
I'm sure you're probably aware of it already, Bob Beck's blood electrification procedure - non-invasive micro-currents from a gizmo you buy/build, coupled with Colloidal Silver.  Details available on Scribd;
http://www.scribd.com/doc/19711965/Bob-Beck-Lecture-CONQUERING-INCURABLES-WITH-MICROCURRENTS
Your mention of soda got me pondering what difference there was between that and something we used to drink all the time growing up - it was called Andrews Liver-Salts here, no doubt you have something similar on your side of the pond.  A quick google brought up the following cancer-related link;
http://www.canceractive.com/cancer-active-page-link.aspx?n=503
QuoteInterestingly, if you go to the doctor in France or Italy with a variety of symptoms they are likely to tell you that you have a liver problem. "Feeling a bit livery" would have been heard in Britain 50 years ago when products like Andrews Liver Salts were commonly taken. Now, if you have eczema, tiredness, sickness or acid stomachs you are very likely to be given drugs which will overwork the liver even more. Yet the all-to-often neglected liver is the start point for good health in all of us.
Anyway, although I haven't used it in decades, Andrews was a joy to gulp down before the fizz was gone.  Bicarbonate of soda is yuck in comparasion...
Cap-Z-ro
Good info in that link sproket...well worth bookmarking.
Quote from Lee:
" Which Dear Cap... thread or forum were you thinking of? "
Well, sorry about that Lee...I'm afraid you got caught up in one of my legendary failed comedy routines.
Regards...
Thaelin
   BSoda has a peculiar salty taste but not that bad. Another glass of
water after does the trick. Not to mention I don't have to keep taking
thoes damn anti-acid pills either.
thay
the_big_m_in_ok
Quote from: Cap-Z-ro on May 14, 2010, 10:09:58 PM
Quote from Lee:
Well, I can be the same way.  My humor is usually confined to smileys.  Thusly:   ;D   ;)   :P
--Lee
yaz
THANKS Cap for that calcium info!! Would have never known about it!
Here's some links for all you frady cats out there ::)
http://www.survivaltopics.com/survival/better-than-bleach-use-calcium-hypochlorite-to-disinfect-water/
And from the American Journal of Public health. Look at top of page 425 where it states...Hypochlorous acid is NOT a poison! DUUH!
http://ajph.aphapublications.org/cgi/reprint/4/5/423.pdf
There's PLENTY MORE good stuff out there about calcium hypochlorite!
Anyhoo, I had a HELL of a toothache  2 weeks ago with a deep sharp pain that went to the top of my head! I think a bit of food was trapped below the gum line on my bottom molar. I couldn't dig it out and the pain just intensified to almost unbearable!
When I came across this calcium hypochlorite thread, I thought I'd give it a try.
I mixed a quarter teaspoon of the powder (65% pool shock) with about 6 or 7 TABLEspoons water (strong solution). I then used a toothpick to pry the gum away from the tooth and used an eyedropper to soak the area down around the tooth. I couldn't believe the RELIEF I had (almost instantly) when the hypochlorous solution destroyed the bacteria!
The infection was really deep down in there so it took a day to get it under control. I even swallowed the solution, with no problems but it does taste pretty bad. I also used it on some pimples and a cut that I had, everything healed up PERFECTLY! Can also be used as a mouthwash to kill any bacteria and bad breath too, but i would really dilute it as it is pretty strong.
Will try the capsule treatment also! That pool shock stuff is amazing and it's been under our noses all this time!
Thanks for the baking soda alkalizer will try that also. Pepto bysmol has bismuth (heavy metal) in it so stay the hell away from that medicine...er..POISON!
A BIG thanks to you Cap-Z-ro for all your hard work in finding and uncovering this hidden info! YOU ROCK!!
