Self-Runner // Gary Wesley's Motor // Torbay
Started by Lynxis, April 06, 2006, 01:43:19 PM
emitremmah
Les,
Were might I find these observations?
Checked under your login and didn't see anything yet you have 47 posts.
I have a lid but I know it is only first generation. It is 2 half circle arcs. One rests on the rotor magnets and the other rests on the top of the rotor. It has a simple balsa wood angle to push the stators down.
But I can't do that when my suports are falling off the stators
Hammertime (emitremmaH)
An empty cup
gyulasun
hello hammertime,
see this 2 page thread here:
http://www.overunity.com/index.php/topic,1579.msg14030.html#msg14030
Keep up tinkering, sooner or later you succeed.
Gyula
emitremmah
Hello,
Would someone create a flux diagram of this setup. Remove magnet 6 from the equation and reduce magnet 7's strength as it is not on the same plane.
TIA
If printed on a 297mm x 297mm this is almost exactly my setup.
Hammertime
An empty cup
emitremmah
Explaination of above image.
Rotor turning clockwise.
Magnets 1,2 and 3 are exerting the rotational force.
4 and 5 are insignificant on the other side of the rotor.
6 is lifted above the leading edge flux
7 is being almost lowered unto position equal to magnet 1 and does contribute slightly to the rotational energy due to the existing rotational movement.
As stated earlier it takes 2 magnets to lift one so the work of magnets 1 and 2 have raised magnet 6. 4 magnets in this configuration will lift 2 so hopefully that is less than lift 1 and lowering 1. Gravity and magnet 3 contribute to lowering magnet 7 with I hope surplus energy to keep rotational energy.
An empty cup
lwh
"Hello Les,
I agree 100% with your statement about the fact the horizontal rotor magnet must have some length. This is so that stators can be lowered towards the middle were the flux is the weakest. If the magnet is to long it will change pole to n-s on the ends instead of inside/outside.
Say for a 4 inch length if you place a north face magnet stator withing the first 2 inches it will repel in one direction but if placed in the last 2 inches will repel in the opposite direction. movement of the rotor does compensate for this slightly. But there is a definite balloon effect around the ends of the magnet.
One thing that I notice most people try to do is use Neo magnets. I personnally think they are to strong to work in this configuration. The magnitude of the flux field is to great. You would have to move the stators a far greater distance awat\y from the rotor to get away from the balloon effect.
I also believe that 7 magnet stators is the way to go not 8. I am uploading a new pic of my layout. Almost 1:1, off a few mm. If you look at the way 7 magnets set to the rotor you can see it is always off balance especially as long as the magnet in from of the rotor is missing. I explain where I am working from.
I think you did very well with your tooling but again I would not use metal objects which again will effect the lines of flux more than orgainc or plastic will." - Emitremmah
Replying here to your post in the other thread so as to let that thread sink back down quicker.  I don't really have anything to add though.  I can see by your explanation why you need to redo the stators before anything else.  I think you're right about the magnet types/strengths and avoiding using a lot of metal in the construction, but I don't know that from first-hand experience or anything.  If what I said in the other thread about the Torbay design hasn't put you off, then by all means continue with it.  As I mentioned, yours seems to be the most accurate replication attempt so far, as far as I can remember.  I'm hoping that will make a difference in terms of the results you get, but at the same time, I don't want to encourage or discourage you.  I just want to see what you come up with.  Sorry I can't be more helpful.
Les.
