KIPPER MOTOR - GENERATOR Overunity Device.
Started by FatBird, May 16, 2010, 10:29:48 AM
FatBird
It's FREE to the person RECEIVING it.  If I hang a LARGE antenna out in the yard, I am getting FREE juice.  It may be costing somebody else money to TRANSMIT the juice, BUT I am getting it free of charge.  Same with Solar Panels.  It is FREE to me.
Look, if I give you $100 it is FREE to you.  Yes, it will cost me $100, BUT it is FREE to you.
What's free & not free are really BASIC principles that economists learn in Econ 101.
gauschor
Nobody will spend his money on a big microwave transmitter in order to let people freely collect it. It's the same when trying to collect electric power from radio stations: you can say it is "free".
Then ask yourself what good is it for? Once the station is off, you are off too. I'd rather have a device that is completely independent from official institutions, everything else is peanuts.
mscoffman
Those microwave claims are lame. Nobody with microwave
experience would knowingly put themselves into the path of
a beam powerful enough to activate this motor generator.
But these knot "coil" and scramble wound coil things are symptomatic
of a static electric antenna designed to pickup free electrons rather
then intercept EMF. One way one could decypher that one wasn't
picking up EMF would be to build a non-inductive antenna. Wind 1/2
the coil in one direction and 1/2 in the other direction.
Kind of a discordant note was sounded when he talked about a
permanent magnet alternator...No car has one because that type regulator
requires that one dump the excess energy to create heat. The battery
requires a regulator to not be burnt-out via overcharging. The field
of a normal alternator varies the effective mechanical size of the
alternator to meet current demands. A different better regulator
circuit is available for alternative energy sources when using standard
alternators.
So a permanent magnet alternator only makes sense when you don't
have a battery based load to worry about.
As for the melted wire, I previously told you to use a lower gauge power
wire. ;D
:S:MarkSCoffman
FatBird
1.  Excellent points Mark about how he wasn't picking up microwave energy.  I totally agree.
2.  Kipper's list of materials lists a regular NAPA 213-4011 car alternator that he used.
3.  I believe Kipper's mention of a Permanent Neo Magnet alternator was on his "wish list", & is NOT what he used.
4.  His coils of wire remind me of Don Smith's coils.  So I suspect that Kipper's coils are necessary for the unit to put out overunity.
gauschor
Quote from: mscoffman on May 17, 2010, 08:05:43 PMNobody with microwave experience would knowingly put themselves into the path of
Think again, there are people (e.g. Hubbard) who have used Radium to create a "free energy" device. Not reasonable you say. I agree. Fact is, however people do unreasonable things, even when putting themselves into danger - be it because of ignorance or other reasons. Kipper was also one of these "wizards". Hence, if you still want to believe... good luck in hunting a myth.
