This device is the real self-running overunity?
Started by Arthurs, May 17, 2010, 03:45:15 PM
zapjosh
Quote from: gauschor on April 20, 2011, 08:17:50 AM
@zapjosh:
1) I would like to know if you can feedback the generated power from the coils via a rectifier or cap depending on the type of current the motor needs to the motor and then cut off the power source.
2) Or can you remove the power source completely (without feeding back the generated power to the motor) since the device will accelerate on its own due to the magnets?.
Can you try these?
This can not be done yet because it has to be build better and it can not run that long Because there are some thing that need to be lubed!
Airstriker
Quote from: zapjosh on April 21, 2011, 08:07:26 AM
Showing you the magnets is not a experiment!!!! The only way I can show you rotating magnets it to spin the magnet with me finger and tape it. Like a sad you can not see them rotate.One of the only ways is by experiments. And the outher way is by get a high spped camra. Who is your dear? ???
Sorry man but I don't really get you. I'm outta here.
nickle989
@ Airstriker  ... the rotating magnets are the round ones that are suspended.  When the arm rotates it also causes the magnets to rotate .... the magnets will also rotate from the coil but not as much due to the vortex spin on the achieved center line.  Hope that helps.
zapjosh
To let you all know, I will be doing a video in a few day. Thanks for Hanging in there.
zapjosh
Where is an update on what I have been doing. When I was make a video on the input and output,
my regulator got shorted out and stoped working. :-[ I order some part to fix it!
