This device is the real self-running overunity?
Started by Arthurs, May 17, 2010, 03:45:15 PM
Bruce_TPU
Hi Airstriker and ALL,
I saw the importance of this man's work before this thread was started and posted it here:
http://www.overunity.com/index.php?topic=6116.msg238870#msg238870
I asked Stefan to make it a "sticky" which he did.  I will also ask him the same for this thread.  That is how important this is.
You all would do well to listen to Airstriker.  I believe he is correct and that this is a path towards using Lenz law and the law of angular momentum and Newton's third law: law of reciprocal actions to work FOR us.
I also really enjoyed the little simulation.  Notice that the two closest to the axle ran the fastest.  That would be a great set up.  Make the larger rotor small and light weight to gain even more speed!  Really great stuff and I hope that some will take it to heart.
I have been actively planning to adapt this to my unipolar generator I am building and now I have even more ideas.  Thank you Airstriker!
Cheers,
Bruce
gyulasun
@Airstriker,
In the video ( http://www.youtube.com/watch?v=V3UsrfHa4MQ ) it is not shown that the wheel the man holds in his hands was speeded up first, the wheel had to be speeded up by an input energy, ok?
Now I ask if the inventor's rotor is at a total standstill, cylinder magnets are at a standstill too  and he starts the main rotor shaft spinning by switching the top electric motor on, then why will the cylinder magnets also start rotating around their own axis?  So far you have not proved it, sorry.
Because it does not turn out from your computer simulation that the magnets will start rotating.  It is your assumption, you assign a constant acceleration to the magnets. IF you think that the magnets start accelerating, when the main rotor is started to rotate, then please prove it in practice.
And from the inventor's videos we cannot see the magnets are speeding up when the main rotor is started, it is not shown, unfortunately.
Respectfully,  Gyula
Airstriker
Quote from: gyulasun on May 24, 2010, 08:47:14 AM
@Airstriker,
In the video ( http://www.youtube.com/watch?v=V3UsrfHa4MQ ) it is not shown that the wheel the man holds in his hands was speeded up first, the wheel had to be speeded up by an input A, ok?
Respectfully,  Gyula
All in it's time...
However, it's not that easy to be shown on the video. Note, that if you stop the main rotor suddenly, then by doing this you will accelerate the magnets and they will start to rotate in the same direction as the rotor used to. So, if they were rotating counterclockwise, now they are rotating clockwise (all according to the said laws).
The only way to show, that it really is how I'm saying it is, is to stop the main rotor without apllying any back torque on it.
You can ask - why not show the whole rotating thing during the motor action ? Well... I cannot see it by my eye, but If you possess any high speed camera...
exnihiloest
Quote from: scotty1 on May 19, 2010, 08:13:11 PM
So now I have to say that the magnet should be as "A" which makes sense according to the drill test that was shown in the videos.
If it is as "A" then the magnet is not rotating on its own axis so the coil will push it away and the force will not be directed to the main rotor as I saw in my test.
Hope this helps.
Scotty.
You are right. In case B, the magnet would rotate about its magnetic axis which is the same as its geometric axis. When a magnet rotates about its axis of magnetic symmetry, its field remains static therefore there would be no effect with the coil.
LarryC
@All,
I agree with the results shown for A and B as tested here, but I think we are overlooking a lot of issues that Wendel has pointed out.
In his first video (self runner), he states that the motor runs on magnetic pressure.
He has magnetic compression bearings on both the magnet rotors and central rotor. All rotors have adjustable nuts for alignment.
Some have said that the magnetic compression bearings are not needed, but is that true. What if the magnetic compression bearings are required for the effect?
In the jpg below, I've shown a very simplistic scenario of what may be occurring.
1: The magnet has come under and charged the coil which will push the magnet down, which is allowed by the magnetic compression bearings.
2: The magnet downward movement causes the coil to reverse polarity.
3: The reverse polarity causes the Magnets upward movement which causes the coil to change polarity and push the magnet down again.
The polarity changes would allow for the spinning of the magnets.
Any constructive comments appreciated.
Regards, Larry
