Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
billmehess
Dingus my friend your just not getting it. One last time- the clock when fully wound will run for actually 30 days straight. I have only said 28 to have a safety margin. So lets stick with 28 days.
During that time I can produce enough electricity to rewind the system MULTIPLE TIMES to keep it running continously.
A closed loop system re-engerizing itself over and over and over
without ANY external input. Totally closed loop.
The clock only runs down about 1/2 turn per 24hr. Or 2 turns in 96 hours/4 days. In that four day period I can produce enough juice to
turn the clock ( and keep the system running) 4 times.Twice what I need! Remember the clock is running down at a linear rate.
Dingus Mungus
Understood Bill,
Thanks for your patientce, replies, and updates. I hope to read some more conclusive data during your next tests. Good work!!!
Thanks again,
~Dingus
slncspkr
hello bill this is jose, following your invention.
   I have been doing the same as you are doing for a while. I just have not posted annything yet but here it is a description of what I'm doing...
instead of rewinding the clock I am using a smaller system that uses guess what? 1 small aa battery that runs out in about 2 or 3 years.
this is what I a doing...
since it is a smaller system, for shure I am getting a lot less power that the 1 your getting but still I am able to get1.3 volts in about 1 minute or so.
this is what I did...
I used 1 brand new batt.1.5 v and I connected a small motor to it.
  The motor ran for about 10 minutes at about 1,000 rpm. it is a very small motor.
and then I charge some caps with the system(1 pendulum only and 1 coil and magnet from 1 of those hand shake flashlights).for about 1 minute up to 1.4 v.
and I connect the same motor to the caps and the motor makes only 1 spin .if you do the math...
so I believe in yous system...keep it up
sincerelly.
Jose.
MeggerMan
Hi Bill,
Good work.
Can you be sure that there are not external transmitters or transformers nearby that could charge the system through the diodes you are using?
Its just that a very similar experiment on this forum:
http://www.overunity.com/index.php/topic,1720.0/topicseen.html
used this principle to charge up a capacitor to drive a pulsed coil to power the wheel.
It should be possible to work out the power generated if you know the capacitance and the voltage rise per minute.
I will try and dig out the equation for you.
I was thinking of ways that you could improve this experiment by getting the magnet to cut the windings with a stronger flux density.
I am thinking about a rotating disk(s) with two sets of neodymium magnets either side  of a fixed coil cutting in from the perimeter.
The coil could be wound in a trapezoidal shape with each set of magnets cutting each leg, north-south for the first leg and south-north for the second.
Rob
billmehess
No transformers near by. The emf is generated strickly by the magnets moving in and out of the coils.  Back emf is very very critical. I was having a lot of problems with that but I have solved that problem but it cost me a reduction in voltage produce down to 140 mv/min. This is still pleanty to run the system as at that voltage I can completely rewind in 5 days. Remember I have up to 30 days.
The 1.2 farad large cap with digital readout is incrediable it gives me the power I need to run the motor. The 1.2 farad cap itself is being charged up by a large bank of 4700 uf 50 volt caps.
I think the equation you are refering to is e=.5(c)(v)(v)
This will give you the energy produced. Divide that by the total
wattage used by the motor under the load of turning the mainspring and you have the number of seconds the motor will run.
I will be rewinding the clock spring at 6 second intervals. I will do this only twice in the first 5 days. Remember this will then power the unit for another 25 days. Rember it takes only 12 seconds per month or "motor time" to keep the device running continously.
Again no external imput, completely closed loop!!!!
