Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
billmehess
I think the problem with the quartz movement is that it requres a battery, or a steady flow of voltage to run it right from the start and continously throughout the running of the system.
Remember the beauty of the device I am showing is that the motor only need to run up to 12 seconds per month to keep it going continously.
pese
@billmehess
Take only Goldbonded-Germ-diodes  1N270 or 277
Not signal diodes as 1N34 1N60 that have higher Vf.
Also Collector-base junction from Germanium transistor can  used.
Pese
billmehess
Pese I'm not going to explain this system again I guess you just don't get it. The term "free energy" is meaningless.
One last time this is a closed loop system that functions without any external energy being applied. Please give me even one other device
that you know of that has been built that will do this.
MeggerMan
Hi Bill,
I built a magnet motor yesterday using a 0.5Kg spool of wire and some ceramic magnets.
I can just get it to rotate against the earths magnetic field with just 5uW,
(0.000005 watts). I have to manually apply power to the coil to get it to rotate.
This could be replaced by two thin wires shorting on a small commutator on the hub.
This was in the hope of repeating your idea but with a rotating magnet.
The thing is that I do not see how I can get any more out than what I put in.
If I short the coil out you can actually see the drag it causes on the rotor and it slows down very quickly.
You must see something similar where the pendulum is dragging slightly as it enters/exits the coil because you are loading the coil with capacitors which act as a resistance until they reach the same potential as the coil's peak voltage.
I don't know how you have managed what you have but I take my hat off to you, what you have achieved is brilliant.
Rob
billmehess
I encounterd the same problem with the pendulum stopping when it left the coil I solved the problem and when I post I will tell how I did that.
I am in the process of reassembling the device. Right now my work shop looks like something out of Fankensteins laboratory.
I want to present a professional looking device that will be clear in its function and leave no doubt that it works. I have a large number of 4700mf cap being shipped to me from Texas. I was able to purchase them for only 87 cents each as I bought a over 550 of them.
As soon as they arrive I will put it all together, post all data and videos and open my home up to any one interested in seeing the unit.
I plan to ask Sterling  Allen to test the device for validation.
