Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
FreeEnergy
lol this is great news! pass it on people!
d.klutch
Well, I hope you can prove me wrong.....but I think that the power needed for the gear motor (or whatever you are going to use) to wind the main spring back up will exceed the small amount of energy you can generate with the mechanism.  Yes, you only need to run the winding motor for a few seconds every 8 or 31 days, but main springs need a huge amount of torque to wind...and a gear motor that can develop that kind torque will need more power than you can generate. Hopefully, I am missing something here.   ;)
Dave 4664
hartiberlin
Yes,Bill, Dave is right, the gear motor will need more energy, than you can generate, at least in theory.
Try it with a big capacitor first and let us know, if you can rewind the clock with it, without using a battery..
If you use a battery you have to wait too long, until it is drained...
billmehess
The necessary power to turn the main spring of the movement will not be a problem. Remember
the amount of stored energy necessary to do this is accumulated over 31 days. Each permanent magnet/coil configuration is producing voltage it is only necessary to have enough of these to provide what ever is necessary to turn the movement.
Also what if I simply walk up to the device for 9 seconds every month and manually wind the movement. The self winding concept is simply to satisfy the "purist" who what to see a device producing enough to in effect reenergize itself. This does not alter the fact that this is indeed a free energy device and will work continouly as long as the movement is working.
FACT:
A permanent magnet moving in and out of a coil will produce a electric current
FACT:
Each magnet/coil combination will produce lets say 1 unit of power thus 10 will produce x10 and 1765467364 will produce x 176546364 -get the picture. The amount generated is scalable to almost any amouint for any purpose.
FACT:
A pendulum from a mechanical movement can move this magnet in and out of the coil for 744 hours(31 days) See my web site www.geocitiies.com/auction606/index.html
Also these FACTS are indisputible. Connect the dots. This unit will work.
Its so simple!!!
billmehess
Woops- put an extra "i" into geocities. Sorrry again web site is:
www.geocities.com/auction606/index.com
