Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
Dingus Mungus
I don't mind waiting a little longer, I just wanted to make sure you were still around.
Let me know when the public demo is and I may fly in or send a friend from Seattle.
Please please please confirm the best you can before hosting a demo as I would hate to spend good research money on a unnecessary trip. Thanks for the updates! Good luck!
billmehess
I will confirm everything. At the demo I will hand out a spec sheet on the device and answer any and all questions will no reservations what so ever.
As I value my time I value others time. So there will be no surprises or anything hidden.
Dingus Mungus
I hate to pry but when you said "it will take me another week or two to finish up" do you mean finalizing tests or tweaking of the device? If you mean you have had positive results up till now and you are now in the phase of measuring the excess energy then that would really get people interested in coming out for its first demo.
billmehess
I have postive results in such that I can rewind the device from its own power without any external input. The device uses a large bank of capacitors over 800 of them. And I am still putting them all together. My output from the coils is between 500-600mv per min. as you know you cannot just dump this into a single cap. I have to charge a large number of caps one at a time. I am using a matrix approach where I charge the caps individually. They are arranged in parallel strings and the strings are arranged in series.
When I have charged up each cap and the entire system is charged to a certain voltage it is then dumped into a large 1farad capacitor arrangement that is used to run the motor.
When the large mattrix dump happens into the 1 farad cap this must be done multiple times to build the 1 farad up to the voltage I need to run the motor for the required time. I have done this miltiple times. It takes approx 68 hours to charge the device. This turns the clock key 2.6 times. One complete turn of the equals two days or 48 hours.
In other words I can now generate in 68 hours enough energy to keep the system continously running for 125 hours.
It is this large bank of caps and the assembly of the device which is taking the time.
I am using the clock hand itself to individually charge each individual cap.
This is kind of a simplified version of the device but it shows the basic running operation.
slncspkr
Anybody heard from bill yet?
