Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
billmehess
Ok here's what's happening.
I'm not going to be overly specific but the device is in it's final build and functioning correctly.
First moving the magnet(s) thru a coil via the clock mech. will not generate enough
voltage. The two magnets I was using connected to a 4700mf cap. will generate about 150mv/ min. Not enough. I have read many posts on overunity saying you need to just connect up a bunch of caps to store voltage. Won't work. Caps in series will allow you to store up as much voltage as you want but the total storeage capability will be reduced by the number of caps used. In other words 10 caps in series charged to 1 volt each will read 10 volts but the energy stored is devided bt 10. This is a dead end street. Storing energy in caps in parallel will store the energy but the initial voltage does not increase.
The answer is to have sufficient working voltage generated at the source to charge a bank of caps to 12 volts. When I turn on the motor 12 volts will discarge from the caps to the motor and turn the clock mech. one complete turn. I am using a 30 day clock movement. It takes 12 complete turns to wind the clock hence each turn is equal to 2.5 days or 60 hours. I can generate 5 mv. per min or 300mv/hour, do the math and you can see how I generate the 12 volts necessary to keep the device running continously.
The breakthru was using good old gravity to instead of swinging the magnets thru the coils I  have found a way to use the clock to "drop" them thru. Again not to specific at this point but each "drop" will pump 5 mv into the cap. bank. The cap. bank is 213 4700mv 25v electrolytic caps. in parallel. This gives me a 1 farad cap with basicly no leakage.
Stay tuned
I have been running the device now continously for 2 months.
When I finish up this final build I will ask Sterling Allen to evaluate it thru the New Energy Congress as well as showing it to the public.
Dingus Mungus
WOW! Bill is back!
We were worried for a while there.
Glad to hear you are still doing R&D.
I'm excited to hear more, and I'll see you around!
~Dingus Mungus
billmehess
Received a number of emails inquiring about my progress. So here is the status.
First I can rewind the clock mechinism to keep the unit running continously from the power generated by the magnets dropping into the coils and being stored in the bank of caps.
This alone is something that I truely feel no one else has ever done in reality!
This is in itself a self runner.
Since I can charge up the caps in a shorter time it requires to run the device I have additional energy stored in the caps- this is a good thing!
Is it practicle at this point as a power supply doing extra work. Probably not. BUT
this is proof of concept. The first microwave was 800lb and 6 feet tall, the first airplane flew 100 + feet at a height of 12" etc.
I have watched the alt. energy sites for years and have seen 100's of so called working devices, with out fail NONE of them have so far panned out. My unit works because of the unique need to only energize the prime mover only periodically. In this case just 1-2 seconds every 60 some hours.
As we all know it is very easy to design a device much harder to build it. As I assemble the final model for demonstartion I am constantly revising as the need developes. Litttle things like a copper plate that connectly to a sproket having to be replaced because it bends under a small weight. So I have to disconect a big portion of the device to replace with steel plate. Constant upgrades and changes. But that is the device going thru a evolutionary process towards completion.
I want to show a final completed device with no flaws that is my goal.
When I have completed the device I will as mentioned ask Sterling to evaluate it thru the New Energy Congress. I feel his organization and dedication to this new industry is unparralled in both scope and integrity.
I will also freely show the device to the public in a open and non biased demonstration
in Portland Oregon, USA
I consider it to be a privilage to be a member of this OU community and as aways I thank Stephan and this great site for the chance to post my work.
Thank you
ChileanOne
Hello Bill:
Thanks for keeping us updated. Really interesting device you have developed. I wanted to ask if you have considered to also ask to EarthTech for an independent evaluation of your device, as a way of having more support for your claims.
Regards.
Nution
I like this idea. Have to admit I don't understand it 100% but if it is efficient as it has been explained to be, then its a great leap.
Also, just thinking about it, it really wouldn't matter all that much if it did not put out a ton of voltage. Just thinking about a car engine, you cant power a car with any great results off one small piston. However put 8 small pistons in the design and you can get a lot of power. Same would appear for this device. Think of the device as one piston. If the device charges itself in say 7 days(don't know exact figures, have been a lot) enough to power the motor to reset the drive force, then technically one device could rewind 3 other devices. Then take the power the 3 others produce and wind 4 units off each. That would be like a 16 cylinder engine. And with 16 of them scaled up, you could quite possibly produce a good amount of electricity. Now if it can only produce enough energy to power itself, then its a neat device, but not really useful.
I do give high praise to everyone helping, and especially bill for taking the time and money to develop his ideas. Great work, keep it up, cant wait to see more. Have a good one.
