Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
billmehess
I think I was up to late last night-
Web site is :
www.geocities.com/auction606/index.html
hartiberlin
Bill,
you don?t understand coils and magnets.
If you draw current from your coils you will break the movement
of the pendulum, due to Lentz law ! If you connect too many
coils from which your draw current, the pendulum will come to a stop.
Did you ever try to rewind the clock with a motor connected to
your charged up capacitor ??
I guess you did not yet...
Try it and let us know how much voltage you need on a 10.000 uF capacitor
to rewind your clock ! And then see, how fast you can charge the capacitor to this
voltage.
treb79
Yes, I'm afraid this isn't going to do anything at all. Shame really, It would have been nice to have an OU device that tells the time aswell!
billmehess
The movement I am using is sufficiently strong to push and pull 4 of the 2" n45 cycl. magnets through the coils. I am going to build the bigger unit right away. The next post will be with videos of the working unit. Lenz law will be fairly easy to counter because of the inertia created by the magnets.
See you all very soon.
billmehess
Lentz law problem solved.
The large permanent magnet exiting the coil was exhibiting a lot of drag do to Lentz law dynamics.
The drag was enough to stop the pendulum swinging after just a few moments. I solved this
by moving the coil approx 22" from the swinging magnet and let the magnet swing free.
On the other side of the coil  I placed another permanent magnet of equal size (I have 12 of these) suspended by a free swinging pendulum.
When the magnet that is being swung by the clock movement begins it causes a like movement in the
magnet hanging from the pendulum. This magnet  moves in and out of the coil producing a electric current. Because the magnets are so much larger and stronger the magnet swinging from the clock movement is strong enough to pull and push the other magnet in in and out of the coil Even though the magnet behind the coil is moving slower.
Also in my first tests with the much smaller magnet/coil combination I was only able to generate about 3 mv per hour. With this new array I am generating up to 100 mv per hour
This works out to 2.4 volts per day on with a 31 day movement a total of approx. 74 volts can be stored. This is many times over what will be needed to  renergize the system by rewinding the clock movement with a geared dc 12volt motor hence keeping the device working indefinitly.
I have posted new video on my site:   www.geocities.com/auction606/index.html.
Geocities only allows a maximum size of 5 meg. this video is about 4.35 meg.
This device will be able to run continuously and totally independent of any external power source as well as being able to generate an excess of usable power.
I have purchased a 1/2 farad capacitor, about 10" high and nic. rechargeable batteries. I will be replacing the small capacitor I am using now with this larger capacitor to store more voltage and have the capability of charging the batteries to be used at will.
This device is working, I will continue to refine and post info and video as it evolves.
I believe I have a working overunity energy producing motor.
Feel free to contact me with any questions.
