Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
billmehess
In responce to Liberty's suggestion of charging a capacitor in place of using a battary please consider the
following. Charging capacitors to run a motor that draws 4.5 amps to turn the clock motor for the 12 seconds it takes to rewind it is very inefficient.
The goal is to produce a device that will power itself and allow also excess energy to be produced to do useful
work.
This device will recharge itself much more efficently by charging the battary that is used to run the motor.
After all if it can do this (and it does) it has met all the criteria for a OU device.
tropes
I just recently joined this group and find your device very interesting. How much energy is required to wind the spring compared to the energy created by the device?
Peter
billmehess
The spring can wind in 12 seconds which will then run the clock for 30 days. The motor  is a high torque low speed 12 vdc drawing 2.5 amps running free and 4.5 amps running under the load of turning the spring unit.
The unit can generate around .45 volts in 5 minutes. This is run into a series of capacitors. In other words
over a period of 30 days I can store around 5000vdc. A deep cycle battary is then pulsed with approx 20volts
per second from the energy stored in the capacitors. Since the battary only shows a small 40mv voltage drop
(remember it is on only for 12 seconds) it is quite easy to recharge the battary with a fraction of the voltage stored in the capacitor bank. Hence OU. With quite a bit still stored in the capacitors .Video and all data will be posted next week.
tropes
Thanks Bill. I look forward to seeing the video and data next week.
Peter
sparksrus
Quote from: billmehess on April 07, 2006, 01:33:35 AM
Thank you for your input as to what constitutes a true magnetic motor. I am now ready to post
Please look at the site I have set up:
www.geocities.com/auction606/index.html
Tim Ventura has just posted an audio interview he has done with me as a feature article.
You can access that audio at his website: www.americanantigravity.com.
Its Thrus evening 10:30PM I will be available until 10:00 am Tomorrow morning (Fri) to answer any questions. I will be out of town fromFri-and back Sunday evening.
This motor works!!
"Coming soon..."
is all i got??
