WHAT DO YOU THINK
Started by magnetman12003, May 18, 2010, 02:40:12 PM
magnetman12003
gauschor
I doubt his values are correct: what I have experienced is that whenever I connect a small e-motor (e.g. from toy cars which worked with 1 battery) it used up more amperage than only 0.08. These small e-motors needed at least 200mA. So with a slightly bigger 7-12V motor and this kind of low amperage I think he is doing a measurement error.
magnetman12003
Quote from: gauschor on May 18, 2010, 03:19:18 PM
I doubt his values are correct: what I have experienced is that whenever I connect a small e-A (e.g. from toy cars which worked with 1 battery) it used up more amperage than only 0.08. These small e-motors needed at least 200mA. So with a slightly bigger 7-12V motor and this kind of low amperage I think he is doing a measurement error.
I used three different types of meters to measure the input current while the unit was operating. All of them gave the same reading. The R4 relay in the Bedini Davro setup will only allow low milliamp current.  I dont know why it works but it does. Needs someone else to EXACTLY replicate it for verification
ramset
Magnetman12003
Is it not possible to dump into a big supercap and draw off power to  calculate?
Chet
BTW thanks for sharing this really cool setup!
Thanks Grandma
e2matrix
Hi Tom,  I was wondering if using a single diode (not a bridge) on the output to get a pulsed DC might work for charging some batteries.  An SLA battery might be helped with desulfation this way.  Many of the Bedini SSG's put out a couple hundred volts.  I'm far from expert on this so others may want to comment on that idea.  Any idea what the RPM is on your current setup?
