Anyone have a cure for arthritis?
Started by Mark69, May 26, 2010, 12:47:52 PM
wings
related to free energy:
SCENAR
cell repair and pain management through stimulation of the neuropeptides.
" my comment: I.E. reset the information to the cell and by coherence from the undamaged you recover the right information and you have healing"
http://www.energetic-medicine.net/scenar.html
http://scenarnewzealand.org/?page_id=5
see the device signal here:
http://www.scenartechnology.com/scenar1nt_02_1.html
Bearden comment here:
http://www.cheniere.org/correspondence/071509.htm
"About a year and a half ago, the Soviets finally released a Scenar-Cosmodic  unit (a follow-on to the original Scenar) to accomplish healing in addition to the standard pain relief. The new  Scenar-Cosmodic also uses  Dirac  Sea tickling to alter the vacuum energy in which a body exists and is an ongoing set of precursor interactions therein. But in addition to containing the original Scenar limited-tickling system to alleviate pain, this new Scenar Cosmodic has a second unit inside it which has been specifically designed to produce "much-less-limited" Dirac tickling, so that it also produces  significant healing.  This new healing unit is now being rather openly used by Russian Doctors to treat Russian civilian patients and accomplish tremendous healing results for an extensive variety of diseases. "
giantkiller
Believe it!
Read Dr. Dotto information. He explains why hylaluronic acidis not the cure but an environmental addition. He builds his ring from the known aspects of the valley in Japan where this comes from originally.
We take in chemicals to neurologically address missing chemicals or missing molecules or missing types of electrostatic communication in the dendrites.
The relay snapping in the Lee Crock ckt is equivilant to a microspark gap found in a stun gun. This protocol is broad spectrum and will address any resonant needs of the cell structure. Cheap does the trick. One snap of the spark gap can address a multitude of needs in the body. The low power level gets through the whole body because the nervous system handles this level and protocol naturally.
Don't take drugs, chemicals, or operations. And by all means do not ingest corn syrup or sugar. This speed eats the body and causes undo stress at the cellular level. You can't ring the bell if someone is throwing stones at it. THe noise just doesnt make sense.
I sing the body electric.
the_big_m_in_ok
Quote from: Mark69 on May 26, 2010, 12:47:52 PM
Has anyone have a working cure for arthritis?  I would like to hear everyone's experiences and such.
Thanks!
Mark
http://www.pain-relief-info.com/print_coil_instructions.pdf
I don't try and experiment with high voltage, since I live and a Salvation Army domicile and also there are serious risks in making a mistake with that kind of power.
However, a MMO should do something positive against arthritis, for the most part.  Careful, though!!  Many thousand of volts are nothing to take lightly.
--Lee
MrMag
Quote from: giantkiller on May 27, 2010, 01:28:22 PM
Believe it!
Lee Crocks device is nothing at all like a stun gun or spark gap. The relay is simply switching the device from the positive to negative terminals of the batteries to the screen that your lying on. I used one for about a year. I noticed a difference the first month or so but after that nothing really.
If you want a unit that does what your talking about look up George Lakhovsky. His units were used in hospitals until he was "accidentally" hit by a car while crossing the street. Shortly after that, his machines were removed from the hospitals.
What he said his unit did was not kill the disease but buy resonating your cells, the unit would rejuvenate your good cells so that they could fight the disease. There are many pictures online showing what this unit can do. I should really start a thread for it.
Mark69
There is a lot of info here!  It is tough to figure out where to start first.  Guess I will start with coral calcium, then to lee crock or the Lavosky stuff.
MrMag, if you start a new thread, let me know.
Mark
