Dia. Mag. Alternator
Started by z.monkey, May 27, 2010, 07:34:19 AM
z.monkey
This one is the NeoMag8.  It is one phase, and eight poles.  The magnets and the coils are synchronized such that the polarity is the same for all of the coils.  They can be wired parallel for current, or wired in series for voltage, and do not need to be phase corrected.  The stator has inside windings so it can be wired all the way around the stator, and I do not need to leave space for the mounting tabs.  The mounting tabs are further away from the windings, and the slots are situated so the wire goes away from the mounting tabs.  This one will need bearing plates above and below the stator to mount the rotor.  NeoMag8 has eight more winding slots than DiaMag7-2, and I can make the slots wider if I need to...
Goodwill to All, for All is One!
z.monkey
Loose Cannon...  Hahahahahaha!!!3  Holy Fork!!!3
I put my safety glasses on for this one...
Got an 1/8 inch ID shaft spyder, fits the DiaMag spider...
Found an 1/8 inch piece of music wire shaft, fits the spider perfect...
1/8 inch collet in teh Dremmel...
Driver...
Check, ready for service...
No rheostat...
Oh well, lets go...
Bam!  Runs flawless at 30,000 RPM...
The Voltage jumps up to almost 13 Volts...
Teh lights are blindingly hot...
5 Volt bulbs at 13 VDC...
Holy Fork!!!3
I did make this thing industrial quality...
I have seen The Light!!!5
z.monkey
Just measured teh Amperage...
600 milliAmps @ 12.8 Volts...
7.68 Watts...
Fork Yeah!!!5
Video up in a moment...
z.monkey
z.monkey
The fourth time I ran it I burned out all four bulbs...
Hahahahaha!!!
Open Circuit DC Voltage is around 14 VDC...
Fork Yeah !!!3
