Working Air Battery
Started by lasersaber, June 08, 2010, 11:39:33 AM
jeanna
Here are 2 pix of 2 airbats running a beefy joule thief circuit.
The jt circuit makes 441v spikes when being driven by a AA battery, but with a 25mA airbat, I am getting 45v at 38khz.
The second pic shows the same circuit being run by a 5.1mA airbat. It is a 1/2 inch cu pipe wound with mg ribbon and completely taped. When it is soaked, it gives 5.1mA.
jeanna
plengo
This project is simply amazing. Not only it is demonstrating history of Natan Stumblefield in its primary origins but also opening new doors.
I had an idea. Based on the Big 1 1/2 amp 2 batteries with the tick carbon rod and Magnesium and after a few days it oxidized (here at http://www.overunity.com/index.php?topic=9276.msg246347#msg246347) I thought about:
- What would be the effect of this same battery under a Bedini Radiant charge effect? Would it rejuvenate the Mg battery (NS battery) and reverse the oxidation and therefore promote longer life or it would not help?
I wonder based on Natan's patent that his battery is in reality 3 things at once, battery, coil and radiant receiver (secondary battery if it was a Bedini monopole)  just like this video (http://www.youtube.com/watch?v=ZuQGuXJ02fo&feature=related). That could explain (if my idea is correct) that it would run for a much longer time than chemical reactions allow, all because of the positive effects of radiant energy.
Fausto.
Mk1
@all
I got more detail on the potato lighter mixing fluoride and salt make fluorine ...
Look at this video to see the power of fluorine  :o
http://www.disclose.tv/action/viewvideo/50237/Fluorine_new_Periodic_Table_of_Videos/
jeanna
@MK1. That was a good and scary video. hmm my teeth! ...do not add salt to tooth gel while brushing my teeth?
OR... become a fire breathing dragon in 2 easy steps, using only tooth gel and table salt! No match is necessary!  ;D  ;D
I think I actually have a qualified air battery.  8)
I had forgotten to add the salt when I made my latest, so I made a very strong solution of epsom salts after the fact and both soaked the battery then sat the air battery into what was left which was about 1/2 inch in the bottom of a glass.  It really blasted the lights. My meter said it was making over 147mA. amazing.
Then I let it dry out and it produced less than 1mA. So, I sat it into plain water, and it immediately took off.
After about 10 minutes... maybe less, I poured the water out of the glass and 24 hours later, the lights are not as bright, but they are bright and on and the battery feels dry.
So, maybe this is a real air battery..
That would be cool.
(please recall that this is a 1"cu pipe 7" long with 30 -32 turns of mg ribbon ( = 100 inches) half taped around it, and using cloth as separator.)
thank you,
jeanna
zhak
Good afternoon
I present to you the experience of the life of one man, in Russian
Ð' далеком 18.. (не помню Ñ,очно) году русский ученый Ð'асилий ПеÑ,ров соорудил баÑ,арею сосÑ,оящую из чередующиÑ...ся медныÑ... и цинковыÑ... кружков, между эÑ,ими кружками была проложена Ñ,кань, чÑ,обы изолироваÑ,ÑŒ кружки друг оÑ, друга, заÑ,ем в эÑ,у баÑ,арею залили пресную воду и погрузили в лодку,в лодке был усÑ,ановлен элекÑ,ромоÑ,ор мощносÑ,ью около 2 киловаÑ,Ñ,, баÑ,арея усÑ,ановленная в лодке выдавала примерно Ñ,акую же мощносÑ,ÑŒ, после эÑ,ого несколько дней проÑ...одили испыÑ,ания на одной из рек, элекÑ,ромоÑ,ор рабоÑ,ал бесперебойно, не подвела и медно-цинковая баÑ,арея , выводы были Ñ,акие- без расÑ...ода какого либо Ñ,оплива(за исключением воды, мизерный расÑ...од) можно было пиÑ,аÑ,ÑŒ элекÑ,ромоÑ,ор в лодке, Ñ,акая баÑ,арея очень Ñ...орошо подÑ...одиÑ, для речного Ñ,ранспорÑ,а оборудованного элекÑ,ромоÑ,ором. На эÑ,ом все и закончилось. Ð' далекиÑ... 90Ñ... нашего века во времена кризиса элекÑ,роэнергии в КазаÑ...сÑ,ане я вспомнил о эÑ,ой баÑ,арее ПеÑ,рова и попробовал соорудиÑ,ÑŒ несколько усовершенсÑ,вованную баÑ,арею ПеÑ,рова, суÑ,ÑŒ эÑ,ого эÑ,,екÑ,а в Ñ,ом чÑ,о между двумя меÑ,аллами разделенными водопроницаемым изоляÑ,ором(у ПеÑ,рова была Ñ,кань) возникаеÑ, элекÑ,рический Ñ,ок, соединяя параллельно или последоваÑ,ельно добиваюÑ,ся нужного напряжения и мощносÑ,и, воду для баÑ,ареи лучше браÑ,ÑŒ дисÑ,иллированную, дольше прослужиÑ,(проверено),Ñ,ак как мощносÑ,ÑŒ и напряжение в эÑ,ой баÑ,арее зависиÑ, оÑ, площади соприкосновения Ñ,о вполне логично напрашиваеÑ,ся вывод - чÑ,обы создаÑ,ÑŒ компакÑ,ную и мощную баÑ,арею нужно использоваÑ,ÑŒ Ñ,онкую медную и цинковую(или покрыÑ,ую цинком Ñ,,ольгу) , а изоляÑ,ором Ñ...орошо послужиÑ, Ñ,онкая синÑ,еÑ,ическая Ñ,юль, после собираем баÑ,арею    медная Ñ,,ольга - Ñ,юль - цинковая Ñ,,ольга -Ñ,юль -медная Ñ,,ольга и Ñ,ак далее и получаеÑ,ся в иÑ,оге баÑ,арейка рабоÑ,ающая на воде + небольшой выÑ...од водорода(идеÑ, само элекÑ,ролиз воды). Собрал я Ñ,акую баÑ,арейку из Ñ,ого чÑ,о было под рукой(кусочки медной и покрыÑ,ой цинком Ñ,,ольги), не было даже Ñ,есÑ,ера чÑ,обы измериÑ,ÑŒ напряжение и мощносÑ,ÑŒ, но меÑ,одом Ñ,ыка, подсоединял лампочку 4,5 вольÑ,а, добился яркого горения, баÑ,арея рабоÑ,ала пол года после была выброшена за ненадобносÑ,ью(появился свеÑ,), все Ñ,е пол года пока не было свеÑ,а эÑ,а баÑ,арея давала свеÑ,(маленькая лампочка оÑ, Ñ,,онарика) и позволяла слушаÑ,ÑŒ радио. А Ñ,ак вполне можно делаÑ,ÑŒ Ñ,акие баÑ,арейки, будуÑ, служиÑ,ÑŒ годами, но поÑ...оже не выгодно производиÑ,ÑŒ государсÑ,ву Ñ,акие долгоиграющие баÑ,арейки.
It says: the battery that served for many years, required only sauce distilled water or pure water, consisted of copper foil + synthetic tulle + zinc foil.
Note: no salt in the water! This extends the work!
