Working Air Battery
Started by lasersaber, June 08, 2010, 11:39:33 AM
Pirate88179
Sorry, the link is not working...I will fix it after work.  IN the meantime, you can find it in the forum section under other new battery systems.
guruji
Quote from: Bizzy on February 23, 2011, 07:57:36 AM
Hi Guruji
Actually the wire is incerted into the carbon parallel to the magnesium rod. The reason for this test was just to compare a wire versus copper tubing for electricity production. Since I didn't use a JT for the tubing I didn't use one for the wire either.
Do you have a schematic for the stingo circuit?
Thanks
Bizzy
Hi Bizzy yes I am sending you the schematic it's easy to build.
Pirate88179
Link is fixed now in my earlier post. Use the second link.  For some reason unknown to me, I had to have 2 links, if I remove either one, the second link will not work and neither will the first.....very strange.
AL Electro
Hello everone. My first post here on overunity. I'm new to battery construction but I find it interesting and relaxing to fiddle with.
I'm quite versed and have much experience in building other apparatus such as large pulse discharge electromagnetic accelerators and was a Tesla coil nut back in the 90's running pole pigs hand made caps of various types, including oil filled caps. Medium experimenter size Marx generators (20in. sparks) Cockroft Walton generators and of course lasers of all types. List goes on won't bore you with that.
Anyway, I first saw Lasersaber's large unique battery on youtube which he rated at 1 Amp or so output. I recreated the design to the "T". Same parts same supplier and I've read this thread but I don't see any recreation of his design that verifies the output. the reason I'm asking is because I've done some relatively extensive experimentation on the exact design using high salt concentrations of different types, both wet and dry. At this time I'm intentionally growing salt crystals over the cell. Just messing around with that. Anywhooo the output is nothing near 1 amp. I get 10's of milliamps unfortunately. I'm at a loss where his electrical current figure comes from. I'm hoping it's not based on a peak waveform generated by a joulthief. If that's the case the youtube vid is misleading.
Any thought would be appreciated.
Thank you
Dave
lasersaber
@AL Electro
What size carbon rod are you using?  You should be getting at least 500 mA if you are using a 4" by 12 inch carbon rod and a full roll of Mag ribbon.  Did you watch this video?  http://www.youtube.com/watch?v=Yx_wjlMO3OI  Do not put it in oil if you are going for amps!
Hope this info helps.
