Working Air Battery
Started by lasersaber, June 08, 2010, 11:39:33 AM
DrZoidberg
Did anyone try magnesium chloride? It's very hygroscopic so it might increase the moisture content of "dry" paper.
lasersaber
Day Ten!
Great work everybody!  I am really surprised at the success some of you are having with copper.  I never could get the copper core batteries to work very well long term.
Here is a video of my current long term air batter test: http://www.youtube.com/watch?v=nCdj9TJCZd4
Here are some pictures showing better details:
Lakes
Nice construction layout on the motor, maybe add some build details (number of turns/wire size) etc for others that want to build one.
jeanna
Thanks Lasersaber.
Your video is great, and these close ups are really excellent.
I made the suggestion on the video that when it finally stops you could scrape the crud from between rows of ribbon to see if it helps.
I think the bubble shape of the crud is because you are making H2 inside the mg. That H2 is lifting the wet mg up until it collapses as crud. My guess.
@all,
I also want to say the big one I made has only a thin spiral of tape holding it down and therefore it can get dry, which it has done.
The 1/2 inch one is still going strong moisture-wise. I completely covered that one with tape and I thought it didn't work, but I needed to thoroughly soak it to get it really going. It is still wet enough to work after 3 days from the soaking.
I also have had a carbon mg one that is only 2 1/2 inches that is continuously running a jtc, so ...
These really work.
Thank you for sharing this 'invention'.
jeanna
hmmm I guess I am glad I had to get a few of those reed switches to satisfy the mim order!
Next job is to invent a new reed switch?  ???
knovos
I have been playing for a week with this stuff and what I see there is a oxidation going on by the water with some kitchen salt on the magnesium ribbon (see pictures down under)
When I wanted to peel off the ribbon it broke between my fingers. I used a lot of water so I think the less water the longer the coil will last. I've got 0.53 volt 22 mA on one of these sticks. I used one thin layer of elastic bandage. I pulled the graphite rods out of an old battery.
I saw a guy doing that in this video http://www.youtube.com/user/NurdRage#p/search/2/knc1lSupAwQ
I heated the rod with a little flame several times to get out the tar that is in the rod. Just heating and cleaning the tar with a tissue. A cheap way to get these rods, the structure is soft. Thanks Lasersaber, you got me going with this stuff ;D
Kind regards,
Leon.
