Thanks to ALL for your help!!
falling capacitor charges?
Started by ckreol1, June 08, 2010, 02:55:16 PM
The Observer
Gyus,
This Cap had sat idle for about 4 months... and had apparently charged up to 3.5 volts by itself.
        So I am wondering if it will do that again.
You gotta think the thing would have discharged in the course of 1/3rd of a year.
My understanding is that the dielectric has electric dipoles   -==+.
When they are lined up they act like a battery, just like when magnetic dipoles line up to produce a magnet in a larger mass.
When you apply an electric field to these Caps.. the total electric field is that of the CAP + DIELECTRIC (now that is not canceling itself out).
Some then remain in the same position much like a piece of iron stays slightly magnetized in the absence of a magnetic field.
This causes an a uniform electric field that can move electrons from one side to the other.
I will try shorting it for extended periods... but I would like to see if it makes back up to 3 volts by itself first.
                                                               Looks promising !
The Observer
Paul-R
If a cap falls through the atmosphere, it falls through the Earth's magnetic field.
A capacitor with plates of Al, Cu and another metal between the poles of a magnet
does something interesting. I saw a reference in connection with the Testika machine.
ckreol1
@paul-r
Interesting, I wonder what the logic is behind that.  The testatika has always fascinated me.
@chef
That tube looks like something tesla would build.  I remember reading in one of his lectures about a rotating spark discharge that was extremely sensitive to external fields or bodies.  I think it would start spinning the opposite direction when he approached it even the slightest bit.
Paul-R
Quote from: ckreol1 on June 15, 2010, 04:44:29 PM
@paul-r
I should have called it the Thestatika.
The cap device tha ti mentioned is on page 4:
http://www.free-energy-info.co.uk/Chapter13.pdf
ckreol1
Hi Paul.  Thanks for that link.
I wonder, what do you think of this idea in the attached picture?  There's probably some reason it won't work, and I'm sure it can be improved.  I got the idea from the articles on the wordpress website I posted, specifically the Radioactive Voltage article
Seeya,
George
