How about using air as Mass instead of weighs???
Started by frii143, June 13, 2010, 02:50:23 AM
frii143
Hi,,,
I started out by think that the gravity wheel should run more like a top. So that the mass of the wheel could spin out weights on rods then when it brakes it would put more torque on the small shaft and would have to fight gravity on the back side.
That made me think every time it braked it have to speed up again. Using the air as mass instead of weights would allow for I think a fast speed up. I haven't figured it all out yet. when the sails caught the air they will open up or swing out by hopeful by a weight the pulls them open at the set right speed. Then when it brakes it would ratched back making a wipping motion turning its individual shaft. To get to the speed it would take a motor that would also run a generator. There'd be two generators one powered by the motor and one powered by the divice.
frii143
This is what I think the Arms and Fins will look like. I'm not sure how to open and close them I thinking it will use Centripcal Force thow. A spring will pull them forward. I want it to not slow down at all maybe with a Heavy flywheel it won't.
frii143
Hello,,,
This have nothing to do with this tread I thought somebody may find it useful. The upper weight spins freely until the forward movement would stop from the downward run and engage the ramp on the other side to power it up. There is a chain that connects the two weights. The lower weight turns the upper weight.
On another note I thought that if a weighted ball rolling fast enough it could over come a magnetic field for an instant. After that instant the weighted ball would be lifted up by the magnetic field underneight it to a level where another magnet would push it forward to roll down a ramp then lifted in the same way in a circle track.
frii143
I don't know much or anything about physics so it this doesn't make sense that's why. It to magnets collide its that the same as a Head on Collation. Could the G-Forces be use to push the Magnets pass each other.
frii143
Hi,,,,
These are two air-breathing Scramjets going mach 4 to generate power.
