Magnet Motor from Argentina, part2
Started by hartiberlin, April 12, 2006, 10:41:37 PM
gn0stik
I agree you would have to lift fewer arms with your design, but I would think you'd at least have to lift 2 sets that are 180 degrees from eachother. One set spins it around 180, the other returns it.
Or do you think pushing it back down will return it?
stiffy
Has anyone seen an English version of Torbay's patent? The picture  of the device is of poor quality, can't see what is what.
Jdo300
Quote from: stiffy on June 10, 2006, 11:24:15 AM
You can see some better quality images of the patented prototype on Torbay's website here: http://club.telepolis.com/LICYTA/
stiffy
Quote from: Jdo300 on June 11, 2006, 01:46:13 AM
Thanks, that cleared many thinks up.
Have a look at this picture:
The magnets on the outside (stator) are lifted due to the ramp Torbay made beneath the lever holding the magnets. So the rotor probably has a protrusion that slides along this triangular feature. If this motor runs at all, it is going to make a lot of noise, banging against the ramp and pushing up the magnets to disturb the symmetry around the pie shaped rotor magnet.
kukulcangod
 ??? I have tried 2 cams already and my setting just doesn't move.........I changed the heavier one to a lighter one and still nothing , when in effect the manual method works, showing a whole 360 rotation with just one magnet pushing but....apparently the magnet force is not enough all togheter, and innertia just doesn't cut it for the lighter cam with clear  acrylic spiral ramp regulated by  bolts from the top to assure maximum advantgeous angle......next thing is to try very strong magnets and cuts , I don't think is going to work without with 6 magnets around probably more.......the timing shows to be ok.....Good Luck.
