Magnet Motor from Argentina, part2
Started by hartiberlin, April 12, 2006, 10:41:37 PM
hartiberlin
Quote from: kukulcangod on June 14, 2006, 01:43:09 PM
also Stefan hope you are around to see what's going on in here despite the Soccer world cup....what a party!!!
Sorry for the offtopic reply, but I jus?t found how to view the soccer WM2006
for free on an UMTS phone via Vodafone My PC streaming:
http://www.youtube.com/watch?v=Lvl_Lw4I05U
hartiberlin
Yes, seems
kukulcangod
has also the wrong stator magnets.
You must turn them by 90 degrees towards the rotor axis with their
big surface...otherwise the forces are too weak !
kukulcangod
QuoteHey kukulcangod and all!
Nice pics.
couple of questions: what kind of magnets are you using. are your stator magnets not the usual ferrite magnets that are polarized through thickness? because if they are then check madmaxx's design at page 14. I believe he had the polarization wrong. (sorry madmaxx and kukulcangod if i'm wrong )
Thanks T , the thing is with this radio shack magnets ceramic and magnetized through thickness that if I put them in the suggested side, the will get stuck to the rotor ??? because funny enough I'm using two half moons stacked magnets and the top one rejects the other attracts......so you know I wasn't expecting that behaviour from it , none the less by rising my stators a few milimimeters I would get clean rejection with one rotor half moon. I will try different arrangements will see.Good luck.
2tiger
Hi all
Reading your posts I notice that you have all the same problem.
That the created torque is enough to lift up a statormagnet but is too weak to bring them down after passing them.
So just an idea based on this.
I think that the kinetic energy of the rotor created by the repulsion ist not high enough to do both.
What would happen if you build a unit with a bigger radius so that the rotor magnet has a longer "way" to run "free" and store more kinetic energy in the rotor?
And - if I remember well you all are trying to liftup the first stator just in front of the stator. Torbay uses a rotormagnet that covers three statormagnets at a time.
Have anyone try to lift the third statormagnet in front of the rotormagnet? I think that this would be the better timing. The donkey will run faster if he see the carot more far away as he has it hanging down right in front of his nose.
Please tell me if I?m complete wrong.
CU
2Tiger
kukulcangod
QuoteAnd - if I remember well you all are trying to liftup the first stator just in front of the stator. Torbay uses a rotormagnet that covers three statormagnets at a time.
Good thinking tiger, out of frustration it would've take me longer to get to that detail , it means going back to study original plans etc, that's why I made it in rhino as accurate as possible but constructing -again-with what is available amounts to a lot of brainstorming when time permits, Those are the types of observations we need to correct our trayectory.
I did experiment  with my setting and as I mentioned before, with only one stator my rotor is able to go 360 and lift 2 stators after that , still need to be considered flywheel weight and power of magnets for Torque.Keep up the good work.
