Buoyancy wheel working in vacuum conditions.
Started by Low-Q, June 20, 2010, 05:22:53 PM
DreamThinkBuild
Hi Low-Q,
You have some really good ideas, keep them coming. Here is a patent that uses the bubbles in the vacuum for moving a wheel.
HEAT VAPOR DIFFERENTIAL ENGINE
http://www.google.com/patents/about?id=nBk4AAAAEBAJ&dq=3715885
Using your idea of an IR Led it might take less energy to get going on a smaller scale. Then combine the output shaft or geared with this patent.
Miniature generator
http://www.google.com/patents/about?id=u0DJAAAAEBAJ
Low-Q
Quote from: DreamThinkBuild on June 21, 2010, 12:39:10 PM
Hi Low-Q,
Miniature generator
I can make a small generator that is generating power to a small LED. It can be made cog-less like those in core less electric motors. If there is enough torque in the gravity wheel, it should be possible to run the generator in "overdrive" so it spins much faster than the wheel - just to scale up the voltage to trig the LED. I believe those 5mm IR diodes runs on approx 1.5 - 1.7 volts at 20mA. That would be about 30 - 35mW power. But I believe more than one is required to boil the alcohol in the vacuum tube.
mr_bojangles
love the idea
why not attach an LED on each side, or possibly inside to maximize efficiency of heat exchange
then alternately turning one on while the other is off
this way your still only powering one LED at a time, plus it would increase torque, as both are now subjecting the lever to weight distribution
unless you planned on turning the LED off while the lighter side was in the up position
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
Low-Q
Quote from: mr_bojangles on June 22, 2010, 07:02:46 PM
love the idea
It should also be possible to just make a short circuit coil with very thin wire and many windings, inside the tube, that heats up when passing a N-S-N-S-N-S-... magnet array on one side. Then we have 100% heat to "warm up" the fluids - no loss that is used to not heat the fluid. The wheel will face a counter force anyway if energy from the wheel is used to warm up the fluids. I guess the coil idea, with relatively high resistance, is better than using IR diodes.
Vidar
