New Steven Mark video released April 2006 !
Started by hartiberlin, April 14, 2006, 12:18:43 AM
hartiberlin
But the earth magnet field is a steady "DC" field.
No "AC" field....so how should it then oscillate ?
hartiberlin
Hi Kosh,
I thinkin the big 1 Kwatts unit Steven has 2 oscillators that are powered by small
batteries and that these generate the used 2 primary frequencies, but these then
interact and generate the huge output, this I guess, cause he just switches on the big unit
with an electric switch...
Liberty
I looked at the latest video and noticed on the TV that the channel Steven Marks is watching on one of his tests is in Los Angeles on channel 9 KCAL.  Only California would have marble floors and gates around a property too.  Just thought that was interesting to know where he lives.
Liberty
Liberty
Quote from: hartiberlin on April 15, 2006, 02:22:48 PM
I propose to you, that the earth's magnetic field can be cancelled or nullified.  A local magnetic field would  "mask" the earth's magnetic field and effectively lower the frequency through cancellation of most of the magnetic field frequency.  Leaving a roughly 5khz sine wave output such as Steven Marks had on his device.
Or imagine two transmitters.  One in orbit around the earth and the other one is just outside in your same city.  These transmitters are transmitting the same sine wave at a high frequency.  The one that is farther away will lag in time, compared to the one that transmitted just outside of your city.  If you combine these signals, many of the sine waves will cancel out each other due to being out of sync.  Effectively lowering the frequency of the combined sine wave that is received.  The same would happen with a magnetic field.  The magnetic fields would partially cancel each other out and what remains is apparently 5khz to induce the power in the coil as in the Marks device.
If you take two magnets that both repel, in exactly the middle of the two fields there is no magnetic pull one way or the other.  They cancel each other out because the forces are equal.  But if one becomes stronger than the other, you have a "static" or very high frequency magnetic field again.
Liberty
Liberty
hartiberlin
If you have a pulsating  0 to 0.5 Gauss field you could only extract millivolts
in such a small sized 12 inch device but not 360 Watts !
