FILIPIAK Motor Replication
Started by dani, April 16, 2006, 05:15:11 PM
hartiberlin
Here is a FLASH animation in an *.exe file.
www.overunity.com/filipiak
This shows pretty well the functional principle.
What do you think about this ?
Is it already working in a closed loop
mode ?Or is he just charging batteries with it ?
Nastrand2000
if he is using a two battery system (again i dont see any batteries, could be behind the meters in the video tho), would this constitute an open system? If he is charging and discharging a capacitor (you can see a capacitor behind motor for a second or two in the video), then it would be a closed system. If no batteries are used i assume its a closed system, and if it contiued to run, then this is a feat in itself. This is the next motor i will replicate once my torbay replication is done.
Jason P.
hartiberlin
Have a closer look at the vdeos,
it seems he is using 2 x 12 Volts batteries under the meters,
there are glued these white paper stickers ontop of them...
Nastrand2000
i would have to agree...i didnt see the soldering to the posts of the batteries
mark australia
one of the volt metres is showing 12 volts even when it is stationary...I suspect batteries. However why dont you email him and ask???? I dont speak polish.
I also ....like with all mag motor projects, would like to know how long it has run for and do the magnets hold up after running under load. I think that could also be the reason everyone has gone to cover in Argentina Re the Torbay motor.
Kind Regards
mark
