Conspiracy smashes again an HHO succesor !!! ( sorry for the bad english )
Started by plam40, July 07, 2010, 01:11:08 PM
mscoffman
Quote from: ramset on October 21, 2010, 08:55:57 AM
GET THAT PDF !!
Folks are claiming that if what Freddy is doing is true
It would be 1000 times over faraday!!
@All
This appears to be the REAL Deal. What Freddy is showing is
that the a single tuned tube has a large power efficiency dynamic
range. It still requires a low level "clock" synchronization signal which
itself then power amplifies. It highly suggestive of a self powered
reaction. Of course that would mean a very high gain at very
low input power levels. But a more reasonable gain at the power levels
we would want for an engine. It is suggestive that some sort of
acoustic reasonant system could probably be found that would
be totally self powered. We really would prefer to not have a
chemical-material-only self running system as then it would be self
running sans external controls. But...so far things are looking good.
@Loner
On the Maxx Tronic Max068 PWM Controller.
This was initially a DC motor controller adapted to generate HHO.
Freddy apparently modified his to run lower at 19Hz by using an LM393
circuit, most likely substitute (on a PC daughter board) for the
NE555 timer which indeed doesn't work all that well at low frequencies.
The DC motor controller part is fine as the Final FET Transistors
will need to handle inductive voltage spikes from drive coils in the
electolyzer. Apparently the MAXX Tronic circit was cloned far and
wide in the HHO community. It is not that complicated a circuit.
The electolyzer unit itself is where all the construction effort needs
to be placed. We are going to have to wait for Freddy to give the
exact details.
:S:MarkSCoffman
ramset
Mark S Coffman
to be placed.
:S:MarkSCoffman
I'm sure our buddy "Loner" can help steer that effort
[utilysing his personal experience and resourses].
Chet
Thanks Grandma
teslaedison
Hello Guys,
     That are doing a great work but I would love to put my two sense into the pot if I may because I did an experiment with just distilled water by itself with the use of Paper clip and stainless steel spoon so if you are interested in how I did it by Tesla's AC with Edison's DC working together please contact me below at bottom of this message.
PS : Here is a video showing white pure H2 and O2 white cloud gases below
http://www.fliqz.com/aspx/permalink.aspx?at=5776ccb97e4a432d923e9b4186cad72e&a=177157c753114cd4a05ac46773477d7f
Also more information below too.
      You are not giving the totall account of Dr. Randell Mills processes which he says that the electrons are round shape disks when it comes to a positive proton that the electron wraps around it as a bubble so go check his explanation to what I totally believe is true web site below:
www.blacklightpower.com
http://www.youtube.com/watch?v=Ymlc8nk7Mdk
PS if you have any questions about this to please contact me at any time so I can explain his processes which will evidently become the new wave of energy for the future of all of mankind !!
Sincerely,
Thomas C.
Cell Number: 309-660-4627
