Free energy (DreamYear HHO circuit)
Started by dreamyear, July 13, 2010, 07:10:20 AM
dreamyear
Quote from: luishan on July 18, 2010, 12:32:52 AM
What is the relay manufacture part number or model number ?
u can find this realy at any electronic shop....it's most simple realy... ON and OFF
i'm using 12v 30amp realy
mohitsofat
Hello all
            i want to replicate this project. As i have a very little knowledge of circuit can any body tell me how can i make this project.
Quote from: gotoluc on July 13, 2010, 09:06:35 PM
Hi dreamyear,
I would recommend a change to your circuit.
Your second charge battery connection I believe has a problem. If you want to collect the collapsing field of the transformer 24 volt primary you should connect it Bedini style. See the edited schematic I did for you.
You should do a test of how many amps is drawn when the complete circuit is in operation and then another test but remove the transformer and charge batteries from the circuit to see if the current stays the same. If the current is less then with the transformer attached then there is no gain. If it is the same then you have something ;)
All the best to you
Luc
