Free energy (DreamYear HHO circuit)
Started by dreamyear, July 13, 2010, 07:10:20 AM
gotoluc
Hi dreamyear,
I would recommend a change to your circuit.
Your second charge battery connection I believe has a problem. If you want to collect the collapsing field of the transformer 24 volt primary you should connect it Bedini style. See the edited schematic I did for you.
You should do a test of how many amps is drawn when the complete circuit is in operation and then another test but remove the transformer and charge batteries from the circuit to see if the current stays the same. If the current is less then with the transformer attached then there is no gain. If it is the same then you have something ;)
All the best to you
Luc
dreamyear
thanks i'll test this circuit and check the amps draw
nice nice redraw
Quote from: gotoluc on July 13, 2010, 09:06:35 PM
Hi dreamyear,
All the best to you
Luc
dreamyear
luishan
What is the relay manufacture part number or model number ?
