Rosemary Ainslie COP>17 Circuit / A First Application on a Hot Water Cylinder
Started by Rosemary Ainslie, July 18, 2010, 10:42:04 AM
0 Members and 88 Guests are viewing this topic.
Rosemary Ainslie
Quote from: powercat on July 29, 2010, 05:15:38 AM
Hi Rosie
Re documentary,Stefan is the best source of information on the history of OU research.
I would love to replicate one that works but i am still waiting to see one that has been proven beyond reasonable doubt.(self runner)
After all it's not brain surgery  :D
http://www.youtube.com/watch?v=THNPmhBl-8I
Hi Cat.  Always a pleasure to see you around.  Re the proof beyond reasonable doubt!  It's a new benchmark to demand a 'self runner'.  That's PERPETUAL MOTION!  LOL.  Still somewhat politically incorrect mention the term in polite company.  I see Mitchell and Webb pipped "I research energy.  Not exactly rocket science is it? "  ;D
But the proof is there Cat.  Just confined to rather small values.  But do give us that over unity number.  It's a good start.   :)
Kindest as ever,
Rosie
otto
Hello all,
@Rosemary
nice docu.
So, zipons are the particles. I suppose the positive particles.
Whats with the NEGATIVE particles?
Otto
Rosemary Ainslie
Quote from: otto on July 29, 2010, 06:07:54 AM
Hello all,
@Rosemary
nice docu.
Otto
Hello Otto.  The zipons are neither postive nor negative.  They're dipoles.  So the proposal is that they've got both - very much like a bar magnet.  If they were entirely positive or negative they would not be able to assemble in that orderly 'field' arrangement.
What's being addressed here is a problem with the concept of current flow being based on the flow of electrons.  This is widely used as model but actually has an intrinisic problem.  Electrons are 'like charged' which, according to Pauli's exclusion principle - means that they cannot share a path.  And current flow is based on the concept of a shared path of 'something'.
Here the idea is that atoms are 'held bound' in some kind of solid or liquid amalgams - usually three dimensional.  And the actual molecular and atomic structures are arranged - not so much through a self ordered system - into their crystaline structures - but are arranged by these one dimensional magnetic fields of zipons that bind those atoms into that identifiable amalgam.  When and if they are moved - through voltage imbalances - then they simply change their 'abodes' or positions or spins - to accommodate that imbalance.  So the thing that moves through space as current flow are these fields of zipons.  And they can move in either direction - being both positive and negative.  And they can share a path precisely because they do not have only one monopolar property.  In effect the ENERGY that we measure - is the result of these fields moving towards a state of balance.
The thing is this.  It's proposed that they are invisible - dark - because they exceed light speed.  We can only measure this as voltage imbalance - or see it when an innate imabalance takes them out of that hidden field condition.  And when this happens - when the resistors get hot - then that results in a degradation of the bound state of that resistor.  It effectively compromises the structure itself.  And the recharge/discharge cycle is simply determined by the direction of that current flow through the circuit.  One way will recharge the battery.  The other way will discharge it.
Hope that makes it clearer.  If not ask away.  I'd be very glad to get these points understood.  Not to say that they're right.  But thus far it seems to be consistent with the evidence.
Regards,
Rosemary
http://www.scribd.com/doc/33988924/DARK-MATTER-MFM
otto
Rosemary,
yes, sounds good for me, thanks.
Im not good in theory I think) but Im very good in blowing all kind of electronics, wires,big batteries......and all the stuff around my TPU.
Otto
Rosemary Ainslie
Quote from: otto on July 29, 2010, 06:59:05 AM
Rosemary,
Otto
;D LOL Otto.  Nor am I.  But what I lack in ability I make up for in interest.   ;D But to make good use of this is all that's needed.  Indeed.  And I think you guys have a far better handle on the applications than I do.  Hopefully we'll see all this being put to some good uses.  MUCH NEEDED.  Personally I'm tired of being confined to 'small applications'.  The latest idea is to use IGBT's.  I think it was mentioned here by someone?  Maybe Fritz.  In any event they can take more power.  And we can possibly compensate for that lack of a body diode by simply putting a diode across it.  Hopefully it'll work.
Kindest regards,
Rosemary
