The downfalls of conventional electrolysis - and how to fix them
Started by oswaldonfire, July 20, 2010, 11:30:31 AM
oswaldonfire
Theoretically, yes.
However, there are practical limitations. For example, a cell the size of a test tube putting out that much gas would literally explode all over - there would be too much gas in too small a space being produced too fast.
There are a few others, but I can't think of them right now. My brain is running a million miles an hour!
Got some stuff I'm working on and gotta finish within the next 40 minutes, so I'll be back on later tonight.
slapper
how long before the reaction cools?
closest i could come up with at this time is drano. got about 5 ounces stirred into a 16 ounces of distilled.
it's been about 1hr and it is still quite hot and dark.
here is some more pics.
take care.
nap
we are not alone :)
oswaldonfire
It can take a while to cool down - I leave my solution overnight for at least 12 hours to cool down and settle. Any extra crystals will settle on the bottom - use everything but these.
Looks like a good first setup, and I am very pleased to see that you've already started it.
Only thing I'd like to say is - make sure that seal at the base of the jar is good. You don't want any of this stuff leaking out.
I'd keep a bottle of vinegar around, just in case.
slapper
okay - i'll hold off till tomorrow  :(
had to heat the pvc up and form it around the oblong induction coil.
the pvc tube fit tight in the hole i cut in the bottom of the plastic peanut jar.
everything is a snug fit.
put a bead of some cheap 5 minute epoxy around the penetration both inside and out. pretty rigid.
do you think i should put a thin bead of silicon over the epoxy?
thanks.
nap
we are not alone :)
oswaldonfire
You don't absolutely have to wait until tomorrow if you're fired up and ready to go. The solution will get warm anyway during use.
It shouldn't hurt to try putting a little silicone on, but if you're comfortable that it looks watertight, then you don't have to.
