The downfalls of conventional electrolysis - and how to fix them
Started by oswaldonfire, July 20, 2010, 11:30:31 AM
mscoffman
Quote from: niofox on August 06, 2010, 12:37:03 PM
@mscoffman
Huge thanks for the help, I'm still in the process of self-taught electronics and appreciate that you would take the time out for a newbie like me  ;D
So here's what I've done:
a) Check
b) Check
c) Check
d) Check
d) Made the modification as best as I understood this point
e) This requires a bit more time, so I'll tackle this one after work
"Because of the low beta of these transistors, significant signal
drive capability will be required in the Signal Generator. This may be
better handled by one additional buffer transistor feeding the other
three bases."
Would it be better to do this or just find a more suitable transistor spec to replace the MJL21194?
Thanks again!
Edit:
Forgot to change the solenoid values, but just pretend they are different values each
@niofox;
Better;
- Except;
A) Remove "S" shaped wires to ground. Just have grounds hanging from transistor
emitters.
B) Move battery vertically down to the bottom of page
with ground symbol still attached, stage #3 is still wired wrong -
(still is like it was before)
c) Diode needs to be moved from horizontal to vertical. Diode pointed up
with ground at lower end. The diode gates ground onto the signal
if the ground becomes (+) relative to the signal (-) - while that DC is blocked
from signal generator by the capacitor.
d) Should still have series base resistors in each transistor base circuit to
keep excessive energy out of base - a bare base connection will look almost
like a short circuit to the signal generator - Res. value can't calculated until
coil's DC resistance is measured though.
Bipolar Power transistors all have relatively low beta gains. It's not their fault -
it's a design trade off by their designers.
http://en.wikipedia.org/wiki/Darlington_pair
If you use the above link make the first transistor an NPN 2n3904.
A medium power small signal transistor. You may need heat sinks
on the (3) power transistors if they start to get more than a little
warm. You also may want "freewheeling" diodes across the inductors
backwards from the drive direction to throw away back EMF so the
transistors won't see the large negative spikes. More sophisticated
circuits make use of this back EMF. Especially if the cell starts
to do energy "talk back" to the driver.
:S:MarkSCoffman
nievesoliveras
@niofox
Please start your modifications using this one:
Jesus
ramset
Thanks Grandma
cletushowell
I didnt see a injector even the best gas the best jet fuel the best nitro all get turned to vapor with a mist first why would anyone think hydrogen is different im not a eletricle enegeer but take dr stifflers designs inject the h20 first to vapor add carbon to bond the oxygen charge wireless with frequency find the frequency from our stereo so we can put the frequency converter in our intake manifold and then blow it up then recycle the water and do it again.
ramset
        Tush,
                             You have to be careful with some of those "Vapors"!
        Just say No!
Thanks Grandma
