The downfalls of conventional electrolysis - and how to fix them
Started by oswaldonfire, July 20, 2010, 11:30:31 AM
nievesoliveras
Quote from: ramset on August 07, 2010, 04:35:15 PM
Jesus
If you have a circuit for a single coil?
First let me thank you for your presence here
You are a selfless open source engineer ,that works tirelessly for this cause!
I will try to find out if this circuit can be modified/used with one coil or a different configuration is suggested.
Exx another selfless experimenter/open source engineer,
A good crowd of men showing up here!
Workers,builders,experimenters.
This is starting to feel real good fellows!!
great stuff!
Perhaps this time will be different Chris?
Chet
PS
5 watts  5 minutes  1 gallon of water into gas
I beg your pardon. I did not see this one.
Thanks for inviting me to the thread.
Jesus
nievesoliveras
Quote from: niofox on August 07, 2010, 11:50:11 PM
Yes that is what I had in my head
I thought that was essentially what the proposed experiment was about
When you say "In contact with" the poles ... do you mean the solution needs to extend beyond the top and bottom of the coil?  Like if I reverted to putting a pvc pipe thru the middle of the bobbins and fill that instead?
Great circuit illustrations by the way
Much thanks for this
Usually the hydrolisys is done like the photo shows.
But maybe your original idea can work, you never know.
I dont think that inmersing the coil in electrolite is a good idea, because the electrolite will corrode the material.
Also for the electrons to travel through the water two separated poles are needed.
May be with your idea and the magnetic field created by the coil, the hydrolysis proccess begin. You never know.
Dont give up your dream. Keep experimenting.
Jesus
ramset
Stihl Woody
Sorry to hear you can't continue [moving is rough]
You should look up Chris when your in Alaska ,he seemed to appreciate you and your efforts.
I will test your rig and post here [Emailing my address to you]
Sorry to here you won't be by the "net"
Make the rest of your life,
The best of your life,
Jesus,
I Emailed your schematic to Alaska star, he said it was good.
All
I believe enough info has been presented here to replicate
And he knows it!
Yes It needs some "Fussing
Again Chris's response to my query,
Alaska Star
to me
show details Aug 4 (4 days ago)
I have been reading this thread since ------- started it.
You guys are on the right track.
There's so many variables that you can modify from the size of the coil, the length of the coil, the strength of the coil, the dilution of the liquid, the frequency of operation, whether the field drops below zero line, if the coil has a ferric housing around the winding, ferric ringing, the type of material to make the coil (maybe copper coated steel wire dipped in the enamel to make magnet wire?) and anything else you can think of.
That particular technology for me was to just do it, see if it worked, post that it worked and move on to something else.  It was originally nothing more than a satisfaction of my curiosity.
Chris
He is working very hard on a motor that does things no one has been able to do,
He is a great fellow and lives a very humble life [by choice]
I don't think he is into "The Little Red Hen"  Syndrome.
I believe He shared this once
Nobody really seemed to pick it up and run with it!
Plus it could be that this is something that is in the back of his mind to develop down the road?
But he has Offered to send a running unit to a trusted member here for Open source analysis.
He would have to find time in his 18/7 schedule to do this?
I personally feel without some published efforts ,that would be pathetic [to request that on our part]
We want this, we better show some effort!
High frequency ,Big Gauss, Strong Salt solution
Thanks Grandma
niofox
Quote from: nievesoliveras on August 08, 2010, 07:42:23 AM
Jesus
Well I was making sure the solution never touches the wire by using something like glue to seal the small holes where it feeds through the middle of the bobbin
Although it sounds like you are thinking of a more conventional process the more I think about it
ramset
Jesus
I forgot to post this [your circuit]
I asked Chris Hunter,[the fellow who did this] to verify your circuit!
He said quote:
"THAT SCHEMATIC WILL WORK" [and that's all he said]
Chet
PS
Mark C,says 1500 liters of gas in one liter of water!
1 US gallon 3.8 liters
1500 x 3.8=5700
5 watts , 5 minutes, 5700 liters of gas!
So what do they say? the average ICE [internal combustion engine]
100 lpm[liters per minute] to run at highway speeds?
That goes way off the Holy s%@t scale!
gonna be a blast!! [i wish]
PPS
Chris,
Chasing 12,000 hits here, from all over the planet [and you ain't even here[yet]
You guys wanna change the world?
you have a very good start!
and I will guarantee this is gonna get better!
Thanks Grandma
