The downfalls of conventional electrolysis - and how to fix them
Started by oswaldonfire, July 20, 2010, 11:30:31 AM
ramset
And our friend Farrah [being serious here]
Is sharing a lot of her understanding [and science :o]
Here
http://www.overunityresearch.com/index.php?PHPSESSID=2584ea08c04a7770581c844896609848&topic=389.msg5786;topicseen#msg5786
It should help understand where we have been ,and
Where we are going!![the name of this thread]
Chet
Thanks Grandma
ramset
SSOOOoooooo............
Mr. Hunter,
Hows things?,good I hope!
Chet
Thanks Grandma
ramset
Well, well, well,
Mr. Hunter,looks like you are going to have some SERIOUS competishy in that electric motor bizzness
YEP
Got a fella from up in canada ,says he can eat you for breakfast,pull your D8 20 motor monster Mud flingin beasty
SIDEWAYS, with one foot tied behind his back[excelerater foot]
YEP
You better remember how to make that Gas ,so's you can put that in the D8 too [like nitrous]
Any how have a look  2700%[and counting] OU!
Replication info being gathered for a supervised[by the inventer] replication!
The Thane Heinz, AKA Boom Boom ,CrankyPants, Man Zilla
I can Do 2700% [to infinite] OU, What can you do info?
                     JUST POSTED DOCUMENTS
Right here
http://www.overunity.com/index.php?action=downloads;sa=downfile&id=443
and he is available for Input and replication here
http://www.overunity.com/index.php?topic=7833.new
Chet
Ps
His phone number is in the Zip file[you two should talk]
PPS
What About that Gas??
Thanks Grandma
ramset
Thanks Grandma
ramset
Sig
Yes I have lit the output gas without a lid on the cell and completely blew apart the (plastic) container.
I will never do that again. The "milky looking water "as you describe it, is made up of a huge amount
of oxygen/hydrogen bubbles that are miniscule in size as compared to the bubbles produced with
a cell running in normal conditions...the cell appears to be supersaturated with escaping bubbles,
and as fast as they leave the cell...they cant leave fast enough.
Lamere
I appreciate your observations, but the plate resonance is not acoustic and the ions do not move back and forth.
The movement occurs along the magnetic field lines. You can visibly see that, but not in the vid clip
..because of the poor quality resolution of the vid.
Seb
The electrodes are martensitic ss ..and must be so for obvious reasons.The accelerator itself is a monstrously powerful
industrial AC/DC E-core electromagnet. The one in the vid has a pull strength of just under a half ton (963 lbs).
Its operates at 7.5 amps at 120 volts AC. The variac transformer regulates 0-140 volts AC and is rated for 7.5 amps output
and is required for 3 reasons. Firstly, to regulate the rate of acceleration, secondly to keep my glass test cells from smashing.
I went thru a dozen glass jars because they simply cant handle an instant start-up at 120 volts. The magnetic force is too great.
A regular properly-built (non glass) cell works just fine at instant full power. And thirdly, to watch the dynamics that visibly occur
at different voltages. The amp draw of the cell is not at all affected at any time.. with or without the electromagnet.
Yes 60hz is correct...but that has no bearing on the resonance of the plates. Resonance is caused by, and is dependant on,
the strength of the electromagnet, which is driven by the current as more voltage is applied to it. That is why this is so simple.
...But for anyone unfamiliar with a voltage regulator, you can get away without one with a well-built cell.
Silver
You may be partially correct but I really wont be discussing anything about what is actually happening unless its
with those who have also built one for themselves. There are things going on in the cell that I haven't mentioned,
that are just fantastic to see, but I would be quite happy to answer any questions as to how to make one.
Since this vid, I am using a much differently configured cell and electromagnet which is a bit more complicated,
but my very first one consisted of 2 ss screws in a Crazy Glue container with a small toriod AC electromagnet.
Anyone can make one of those.
But let me go on record ...I am not claiming anything ..I'm sharing it.
If no one finds it interesting ..I will quietly disappear..so fire away.
Mookie
Thanks Grandma
