The downfalls of conventional electrolysis - and how to fix them
Started by oswaldonfire, July 20, 2010, 11:30:31 AM
JamesThomas
osy,
Have you considered doing some videos. It would be really great for you to have a youtube thing going on, so that people can get a better idea and feel what you're doing. It will also bring a lot of feedback and joint experimentation. If this is a big as it could be, then the more involved the better.
We are not what we believe ourselves to be.
oswaldonfire
I understand your concern. You are correct - this is a quantum leap. But yet - it is so simple! It must have you thinking - why did nobody think of this before??? It's too good to be true! That was my first thought.
I only have 30 posts on this board, and those 30 are in this thread. I am labeled as a "newbie".. but this is just based on my number of posts.
The reason I came to this board - and the ONLY reason - was to share this information with you and whoever else is interested in changing the world. I believe that this technology can and will change the world. But we need to make it open-source. Put the knowledge out there, anybody can build one, and nobody can patent it and make billions off of it. End the greed of the oil barons forever.
Oil will become worthless - people will be fighting over putting the useless shit back into the ground... rather than fighting useless wars over who gets it.
Do you see where I'm getting at? Picture a future with FREE energy. We could do anything. We could reverse everything we've done to this poor planet.
That said... again... this is the ONLY reason I came to this board. I don't have any interest in any other part of this board or any of the other ideas. Sure, I bet some of them *might* work. But why should I waste my time on that when I've already got the answer right in my hands?
20 or 30 bucks could buy you everything you need to make your own replication. How much of this stuff do you already have? Chances are, a lot of it.
So yes, my information and myself are real. I'm not some elaborate hoax who has spent an ungodly amount of time researching to make myself sound convincing. Do you agree with my ideas? They are scientifically sound.
Even better - don't take my word for it. Build your own.. see for yourself. You may even learn a thing or two, and that is worth more than the final product.
JamesThomas
Quote from: oswaldonfire on July 23, 2010, 10:29:16 PM
It is not necessary to put the coil inside the tube, per se.. but it could be done. I prefer to keep it outside the tube, to avoid issues with the extremely caustic solution reacting with the coil, and to keep assembly simple.
My first setup was like this:
A one-inch PVC pipe, vertical, about 10 inches long.
Both ends were capped, with a hose barb on the top cap to collect the gas.
800 or so turns of 22-gauge magnet wire wrapped around the outside of the pipe.
A supersaturated solution of NaOH inside the pipe.
Pulsed current fed through the coil.
Absurd amounts of hydroxy production followed.
I boiled off all of the water in my tube in about 10 minutes... I could not get water into the darned thing fast enough.
I ran the gas output through a condenser to make sure that it wasn't steam.
I burned the output gas. Pure HHO.
Now are you starting to see the advantages over conventional electrolysis?
it sounds like you need controls to limit production...who would have thought?
It looks like your unit works well. Just need a reservoir of solution to feed into the reaction chamber, and automatic controls.
For right now though, I find this too much to believe. Yes I will have to build my own.
How about your youtube thing?
oswaldonfire
All that is needed is a reservoir of pure water - the NaOH is not used up.
I know exactly what you mean. Intellectual high/rush is more than any drug can ever give you.
I may see what I can do about posting some videos of the process.
You should have enough information to begin a replication - but if you need help I am willing.
In the meantime, I think it will be beneficial to discuss further the details of what exactly is happening in that solution - so that everyone can understand.
jikwan
this is mindblowing
thanks a lot for this oswald
this will have earth shattering effects due to simplicity
and production output
the amount of water used is a sure sign of big output
we have a pretty good explination of how to build it
i dont know if youre going to be around to answer
any questions eg
incoming water--needs to be thoroughly mixed with baking soda
b soda mixed with water as its coming into chamber? etc etc
zen is the art of seeing everything and noticing nothing
