Help with Ed Leedskalnin Riddle , any idea .
Started by Mk1, July 25, 2010, 11:45:22 PM
Do you enjoy this topic ?
yes
48 (80%)
I am listening . Keep going ! but its hard to understand .
6 (10%)
Your are crazy stop waisting my time , lol
6 (10%)
Total Members Voted: 60
IotaYodi
Quotemagnetic current is different than electric current
Yes it is. To me in its pure form its 2 constant fast moving gravitational fields traveling towards each other directly head on. The weakest fields being center of the poles and dividing line. Man made permanent and electromagnets are made by an electric current. This may be the reason why some think that electricity or electric charge is gravity and vice versus. With the coils on the Pmh being at 90 degrees to the iron,you are pushing the field around in a loop which passes the copper coils on the way,so Im seeing an electric charge being induced into the iron,and when the keeper is removed the charge or spark escapes at the weakest field point on the iron. Even if thats not the case the Pmh still has to be considered an electromagnet and that involves electricity. If Ed used just a magnetic current or field I would think he would have to change the blocks to a like pole,North most likely for push,or south for levitation, or he used the east west electric field of the earth in conjunction with the earths currents and east west gravitational field. If you put the keeper on the pmh and face the poles north or south,with the coils east and west I think you'll see the Earths electric and magnetic fields which are closed loops. Either way you could put an enormous magnetic or electric charge on the iron  chains.
I see similarity's between the Pmh and sweets vta. Both have coils with magnets,though sweets was a permanent tuned barium magnet. Sweet could levitate his device with higher current,but normal operation only took a small battery to start and the battery would be taken out after it started. A 25 watt bulb was a minimum load to start it. The bulb more or less would be the keeper to close the current loop. Sweet by all accounts created a vortex in the Aether with the magnet. Eds wheel looks like a vortex when spun.
What I know I know!
Its what I don't know that's a problem!
Mk1
Quote from: IotaYodi on November 15, 2010, 11:07:00 PM
Tell me where on the core can i connect the volt meter , to gauge the amount of electricity , you can't because they are not traveling in the same direction ...
At least if someone is willing to look at what i am saying without imputing all they know , they will see the tree hiding in the forest .
And yes spinning magnets creates a vortex , great news ... its part of it but not what makes the wheel turn .
As far as when i say gravity force , i mean a pendulum works on gravity , call it what ever you like .
Now tell me did you read the tread ?
Mark
scotty1
Hey MK1, I'm a muso too....in fact I'm a guitar maker.  ;D Maybe if you work real hard and save your money you can buy one...I put Ed's logo on them as well.... ;)
http://www.youtube.com/watch?v=8-JnOKH8Jf4
http://www.youtube.com/watch?v=oC-5GnzIyTA&feature=related
During the day I work as a Mechanical Engineering Patternmaker.
I make guitars because it gives me freedom of expression.
A minor, that is my favorite, so yes I am a minor.  8)
Here is a test i made a clip of.
http://www.youtube.com/watch?v=nM8mqUsAjF0
There is a great battle going on inside the soft iron, but it succeedes in pushing most of the excess magnets out, only to have some other coil put them back in, and when the magnets go in the soft iron they don't want to leave, because the air has much more resistance than iron.
If MK1 spun a magnet in the middle of his transformer he might light a light, but if he cut a section out of the core and spun the magnet he might light 2 lights. The reason is that in the full core some of the little magnets run in an orbit and don't want to go into the secondary coil, but when there is a gap in the core then alot of the magnets cannot make a full orbit, because they don't like the air gap very much, so they get pushed out by the iron into the secondary and the result is more light. They try to dam up in the iron but it pushes them out.
penno64
Hi Mk,
I posted this is your other FORCE 1 thread. Thought I'd put it here too.
@MK
You have got to try transformer laminates.
From a couple of burned out plug packs, I simply hacksawed off the copper windings.
You will be surprised.
Regards, Penno (Garry)
Give it a go, eh!
Mk1
Quote from: scotty1 on November 16, 2010, 03:42:47 AM
Actually i will spend 80 bucks on wood and build my own , , i have been playing for 25 years , and building for the last 10 years ... I seen your PRS type axe not my tea bag ...
I also know you got a wheel , that doesn't tell me that you know how it works ...
I just have wish that people would at lest look at what i am saying.
The last drawing i made was for the first ring , but you know you need to ring twice ...
The second force is gravity , like gravity is the force on a pendulum .
Mark
