this will get rid of arthritis.
Started by 11:11, July 29, 2010, 08:57:46 PM
There's also the work of Dr. Simoncini who uses baking soda in conjunction with a alkaline diet to kill cancer. But the main reason is to alkalize the body. So it might be useful too for arthritis.
Also since it's due to a lack of oxygen, what's your opinion on hydrogen peroxide?
the_big_m_in_ok
Quote from: broli on August 17, 2010, 07:27:43 PM
H2O2 is famous for being a possible cure for AIDS.
http://hubpages.com/hub/Many-Uses-of-Hydrogen-Peroxide--Kill-Cancer--AIDS
Some say it's effective, others may not.  But, I have no personal experience either way.
--Lee
11:11
any conductor will re-direct electromagnetic radiation.
so if you sat inside an aluminum foil dome,
the 60 hertz pollution would not reach you.
that is part of why the elites demonized aluminum foil,
as hard as they could.
because aluminum foil can block electromagnetism.
and the elites want certain electromagnetisms,
which they are transmitting everywhere,
to reach the population.
i think they did a study,
that showed that low frequencies,
had a dulling effect on the brain.
to the extent that if enough low frequency wattage,
was inducted into a test subject,
that parts of the test subjects brain,
would temporarily turn off.
and the test subject would temporarily experience idiot savant like mental states.
60 hertz is a relatively low frequency.
so 60 hertz is undoubtedly inhibiting out nervous system function.
causing us to be less smart and aware,
as we would normally be.
11:11
i get the impression,
that the oxygen in living fruits and vegatables,
is in a better form for the body,
than H2O2.
eating 4 or 5 apples in a day,
will not hurt my stomach.
but a drop of H2O2,
in a bowl of water,
will quickly hurt my stomach.
it appears that we were doing the best thing all along.
which is eating raw plants,
that we found growing in some field.
not all this wine and caviar stuff,
that is as expensive as it is artificial.
spring5
To BIG M and other members.
H202 is good for you, but it has to be food grade and diluted to 3% of 35%
To help with any problems I suggest you have a good look at this site,   Earth Clinic.
Cheers  KC
