Ronald Classen's H2O Motor Project
Started by rlm555339, April 07, 2005, 12:30:12 PM
rlm555339
Quote from: fleebell on May 13, 2005, 07:39:24 PM
In other words if you apply the 1.5 -3 volts to it when it is in that state do you get just steam or a mixture of steam , h2 and oxygen?? You might very well get the bang you spoke of although I dont want to be around close when you do.
Lee B
Actually, Lee, it doesn't "bang" when it separates.  (so far)  It "bangs" when it recombines.  You'd just have to be careful not to let the pressure of that instant transformation get over 400 psi though, as that seems to be where auto-ignition occurs.  (or that's the general information I understand)
Ronald Classen, 30+ years electrical tech
DADINK
I am new here, I haven't done any work with this "physically" what I have done is researched/designed and made myself sick over this for over 5 years now.
I have developed an engine that has never seen the light of day,
what interests me is you said the exhaust "sucks" which means after combustion of said gasses they "shrink" to a thousandth their initial volume??? If this is correct I suggest fueling "both" the intake AND exhaust and putting 150psi pop safety valves on both "just in case" venting has to happen. "it has to, to some degree" I believe this will solve some problems. I also suggest you either disregard or ban kane, as I see it his initial comments on hydrogen combustion temperatures and flame speeds are similar to "misinformation" that I have been fed when discussing my concepts with government officials that were presumeably "in the know". Those kinds of comments when taken at face value can ruin a whole project or persons personal morale. It did not look to me like a mistake by the disinformation he gave in detail, it looked to me like malicious intent.
while I'm on the subject back to "feeding the exhaust" feed it some hydrogen since you produce twice as much as oxygen.
jalal
hello every body,
im new in this , i made small hydroxy gas generator, one liter water, stainless steel poles, 12v car battery, starting at the time of cranking the engine. my calculation shows to produce 49liter of hydrogen to run the car completly with water, but what i got is 0.5 liter hydroxy, can one help to make beter production,  each 200 RPM in engine speed needs 7liter hydrogen, so we can compine gasoline with in the same engine.
Jalal
DADINK
when you put it that way it doesn't seem so fuel efficient, now does it???
jalal
