Linden Experiment
Started by frankl, April 18, 2006, 06:16:25 AM
wings
another effect related to the magnet is the "Magnetic Neutral Center Concepts" - ?Bloch Wall,?
"This is an area where there is no rotational movement and tremendous energy" from:
http://www.zamandayolculuk.com/cetinbal/vacuumenergy2.htm
CHAPTER EIGHT:  KEELY AND THE PHYSICS OF VIBRATION
Probably the coil provide the modulation of this center and on the plates you can have the voltage, see also:
http://community-2.webtv.net/SkyVessel/MagneticNeutral/
Ciao Marzio
argona369
sm0ky2
if you can figure out how to tune one of those to the natural frequency of the earth, or an octave thereof, perhaps it will generate energy on its own?
as for the center of the magnet -  the flux-lines are so constricted, and close together that they form into a parallel mesh which is for all intensive purposes...  "neutral".
as it resembles the magnetic-eather-mesh of the environment around us.
this is a basic drawing of it, but keep in mind the "lines" represented here in red and blue are actually helix-paths of BOTH N and S, forming a complex mesh.
gauschor
Although this thread is very old and I want to clear something up that bothers me. I also needed a place to put this opinion on though I don't want to offend this specific forum by any means, in fact my following critics apply to other internet sites and forums. I am sure many of you know this picture:
http://www.linux-host.org/energy/elinden.gif
There is some text to be found about the Thestatica picture described which describes how the 700 Volt were produced (taken from here http://rimstar.org/sdenergy/testa/lindenexp.htm but you also find the text in german language etc. on other sites):
Paul Baumann took two small metal plates and put them together with some paper in between (Fig.3) This was like a flat capacitor. Now he placed this "sandwich," holding it with his fingers in the "jaw" of the Magnet, i.e. between the poles. After a short trial to find the best position, he asked the engineer to put the probes of his voltmeter onto the plates. ____'s surprise: there was a voltage of 700 volts indicated! P.B. said, "When you understand this, you know how it works. This is just the beginning."
Now on every website you see this 700 Volt, but in fact, almost no one hast tested out by himself/herself. Please read exactly what Baumann did and repeat this experiment by yourself!
Hint: he hold it like a sandwich between his fingers. Now remember that and keep in mind that Baumann did nothing else than that and put this sandwich - holding in between his fingers - on the voltmeter...
I did this very simple experiment myself and what I found out is that: I had an output of 680. Not Volt - but Millivolt! The operative word is Milli! Obviously this person in the article, who saw the 700 Volt was not able to read the voltmeter correctly and misinterpreted it as Volt instead of the correct Milli-Volt. It is very likely that Baumann also had only Milli-volt and not Volts! Therefore there is nothing magical in that. The principle is based on the row of electrochemical elements whereas the hand - specifically the moisture of the hand plays the most important role. Another one with dry fingers may only reach 200 or less milliVolts.
I tried it out with Aluminium & copper and plexiglass in between and it worked. Also -  there is no need to put it between a Magnet's legs, or even put a spool around the magnets (these are for other purpose I guess, such as oscillation amplifier or else). I also tried it with or without magnet, coil etc. No change. You can test the volts while holding it in the air. The volts stay the same.
While trying to build some objects from free energy devices one will find out, that many websites are really useless. And the same nonsense is being repeated over and over again on other websites - dragging the free energy scene into a mess - simply because most people are obviously too dumb to try out the most simple experiments themselves, and instead spend hours for hours of wondering where this big value had come from...
Please if anyone getting into free energy reads that - try to build simple devices yourself first instead of repeating and posting mistakes from others on new websites.
Steven Dufresne
Welcome @gauschor.
On:
http://rimstar.org/sdenergy/testa/lindentests1.htm
I pointed out that I saw the same thing, measuring as much at 540mV with my fingers and 0V if using a plastic clamp to hold the plates instead. But my conclusion was the opposite of yours, i.e. that I haven't figured out how to get the 700V yet. Perhaps it isn't that few have tried this yet, but that many have tried and chosen a different interpretation than you have. Of course any kind of mistakes or fakery are possible but if we were to go on that assumption then we wouldn't be here.
-Steve
http://rimstar.org   http://wsminfo.org
He who smiles at lofty schemes, stems the tied of broken dreams. - Roger Hodgson
