magnetic perpetual motion machine design
Started by TEI2MINUS, August 07, 2010, 03:03:29 AM
The people who would criticize the design are mostly people pulling stuff out of their behinds. Your only educator should be nature which shows you the answer through experimentation.
What I'm saying though is that this particular concept will most likely join the mountains of unbuilt concepts and ideas. Besides a few expectations here and there there's little to no experiments done on ideas presented by people who are actually alive.
I'm not criticizing you I'm telling you the things as they are so you can use that information to avoid the pit falls others fell in before you.
nievesoliveras
mscoffman
Hold on Broli;
The best thing that he could do if he doesn't want build it is to do a FEMM
simulation of it. FEMM = 2D free magnetic simulation software. This will
show the magnetic field lines. What one would do is to do a number of
simulations moving the wheel(s) by a small amount and showing that there
is always net force vector in a rotationally positive direction. Magnetic field lines are
complicated and you cannot really always tell by looking at the emitter diagram.
There is also the matter of sticky spots that even FEMM may not be fully aware of.
Real magnets too can be highly variable one to the next.
Let's try to solve problems not create them.
:S:MarkSCoffman
mr_bojangles
it gets tricky when talking about how certain magnets would react given a hypothetical situation, because our current physics would basically just say "no matter what combination you have, it will not work"
with any magnet wheel there is a "sticky" spot, millions of set ups have yet to yield anything with evidence suggesting otherwise, your particular idea is a design that has similarities with ideas that have been tried and don't work,
most likely if you built this, the magnets would get stuck in between each other, they would be in attraction and the force required to pull them apart would be equal to any gain from the repulsion of the other side,
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
TEI2MINUS
thank you for the idea of the femm program, i downloaded it, but im sure it will take ages for me to understand how to use it, given that i know nothing of physics. better than nothing though. i think that free energy with the use of magnets is entirely possible. sticky points may just be a result of lacking precision in magnetic strength or placement
