Self Siphoning Water
Started by FreeEnergy, August 12, 2010, 02:43:35 PM
FreeEnergy
I was messing around drawing and came up with this idea,
If you've studied gravity, water siphoning, and capillary water tubes, you should see a clear picture.
the drawing was done free hand by me so its not to its exact measurements.
- edit -- edit -- edit -- edit -
the water tube should be more like a quarter of a circle shaped type of tube.
and i guess the water reservoir should hold a lot of water, probably more than the tube itself.
but the water would have to be spread out in low depth?
and the hoses should be equal in diameter?
- edit -- edit -- edit -- edit -- edit -
MADE A SMALL CHANGE IN THE DRAWING PLEASE REVIEW.
http://demo.physics.uiuc.edu/lectdemo/scripts/demo_descript.idc?demoid=230
FreeEnergy
thanks for that.
this is pretty easy to test out.
anyone else think this will work?
ResinRat2
ResinRat2
Quote from: P-Motion on August 13, 2010, 09:49:24 AM
  ResinRat,
The idea is not based on capillary action. I can go into more detail and explain the difference between capillary action, hydraulic theory and how using vacuum is different.
        Jim
Sorry, I misunderstood
RR2
As is this concept looks flawed considering atmospheric pressure. However you made me thing about an alternative idea. Will post later.
