a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
sm0ky2
@ Cletus
slow down buddy. we're not quite ready to induce armegedon...
1 step at a time.,
Let's take dave's device here,
and figure out how to harness the energy that radiates from it. and get it to do something useful.
david lambright
i...the device i sent to jetijs has a coil inside the oxide core...when i energized it, then put a meter from the inner coil to the tube outside, i was getting a reading of a constant voltage, [very tiny]....i will ask jet to test his device with better equipment than i have......my brother alvin is going to OSU and i want to show the physics dept. my devices...he said he would talk to someone with clout......david
cletushowell
Smoky you got two of
six five pointed stars correct the red and blue the most important
magenta and indigo watch this sit tight thru the bible reading i demostrate it at the end what you need to see
Check out this video on YouTube:
http://www.youtube.com/watch?v=_w-fhdJH9XI&feature=youtube_gdata_player
http://www.youtube.com/watch?v=Q38dmoKGAEQ&feature=youtube_gdata_player
with this you can do vitualy anthing
except weapons
you need
thats i guess my apology for my long off subject
message sit tight thru the bible reading
i dont care if your religious or not
we all gave eternal life it dont matter to me what or where you want to live
when your done here were in a loop anyways
Sent from my iPhone
Sent from my iPhone
sparks
@ rosemary
  love light and peace its the only way to fly.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
gravityblock
Here is a way of taking the Earth's Magnetic Pulse, http://www.uksmg.org/content/pulse.htm , which one can in principle resolve deflections as small as one ten-millionth of a degree. This device can test both the horizontal and vertical components of magnetism.
I think one of the factors which has an influence on gravity is the vertical component of magnetism. However, the attraction it exerts on a body is, with small variations, the same as that on any other body. Thus, it is that the speed of fall in a vacuum is constant. However, this attraction is not due to mass, it is caused by the magnetism with which the whole body is endowed.
This device will allow us to test small variations in both the vertical and horizontal components, which the PMH may influence just like a magnetic storm high in the ionosphere, with a device which employs one of the most sensitive instruments in science at a reasonable cost.
GB
